Kenjaras Hummer H1 Options
kenjara
#1 Posted : 08 May 2014 23:11:11
Hi guys here is my build so far.
I have skipped the initial parts and started building the body first.
I decided to paint my model gloss yellow.
Building and painting the body.
#2 Posted : 09 May 2014 08:56:19
Nice work and congrat's on your first medal Cool
kenjara
#3 Posted : 09 May 2014 22:43:16
Thanks.
The paints I have used are
Tamiya Grey Primer
Tamiya TS-47 Chrome Yellow
Tamiya TS Satin Black
Now to work on the chassis :D
#4 Posted : 10 May 2014 08:27:48
BigGrin Nice work Kenjara, the yellow reminds me of the old cadmium yellows
kenjara
#5 Posted : 15 August 2014 13:27:50
Here is an update on my Hummer Build.
The body is nearly finished.
Most of the little details have been added.
I have painted and added the main lights. Just the side lights left to go.
(See attached photos)
More info on my blog.
#6 Posted : 15 August 2014 15:38:37
Looks superb Kenjara, lovely work...Cool Cool .. Have just been onto your website and think you have an impressive and interesting collection of builds there.... Will drop in from time to time... well done.... Cool Cool
kenjara
#7 Posted : 20 August 2014 23:09:08
Thank you :)
Here I have some photos of the completed Hummer body.
I need to get some better ones on a sunny day.
bugsec
#8 Posted : 20 August 2014 23:35:52
Hi Kenjara,
Looking very good - I'm almost at the same stage adding the lights to the body.
Did you do as suggested at the end of stage 52 and lacquer the body? I've just ordered some Humbrol gloss but still undecided if I should do it.
Graham
kenjara
#9 Posted : 20 August 2014 23:48:09
Yes I did, although I covered any stickers prior to spraying it. You will also need to cover the front headlights. This is not mentioned in the instructions but failure to do so will make them go foggy. Its fine to spray the paint onto painted clear plastic but spraying directly onto clear plastic will cause fogginess. I first learned this when accidentally varnishing a planes cockpit.
bugsec
#10 Posted : 21 August 2014 00:11:43
Thanks for the tip I would definitely have fallen into that one Crying
Graham
kenjara
#11 Posted : 13 October 2014 13:58:48
Last night I finished my Hummer! BigGrin
Now I just need to wait for a rain free evening to break it in. Cursing
Attaching the piston
Attached the exhaust
The complete chassis
A peek inside
#12 Posted : 13 October 2014 15:07:34
Looks really good, you have done a fantastic job.
Hope you get a dry evening
#13 Posted : 13 October 2014 17:19:14
Looks good, like the colour Cool
#14 Posted : 13 October 2014 17:33:28
kenjara
#15 Posted : 14 October 2014 00:34:34
Thanks guys! BigGrin
Got it up and running no troubles as you can see in my video.
YouTube link
#16 Posted : 14 October 2014 00:54:30
Think you have done a fab job on your Hummer,,, very well done....Cool Cool
kenjara
#17 Posted : 14 October 2014 09:55:34
Thanks Gandale!
Had to amend the idle needle a little as it was way too high.
I used the old hair dryer trick to get it up and running initially as it was so cold.
The initial settings for the transmitter throttle were by default back to front. This meant when I tried to apply the brake it revved up initially which gave me a surprise.
This was easily fixed by reversing the throttle using the switch on the top of the transmitter.
#18 Posted : 14 October 2014 10:00:35
Well done and congrat's on receiving your completed build medal.
Have fun Cool
This page was generated in 0.166 seconds.
