Joined: 16/03/2014 Posts: 516 Points: 1,563 Location: Perth Western Australia
arpurchase wrote: Hi George Looks a treat even with your misshaps you pulled it off Regards Andy Hi Andy Appreciate your comments greatly. I'm glad it is done to that stage anyway. Regards George1 Building HMS SOTS
I have a problem I can see happening when row boat cut from base. Where the stern is there is an angle piece that the stern fits against. This was glued to it as instructions, but now when I look at it the angle piece is actually higher than the black shaped line on stern when it is to be cut away Any advice on this appreciated? See Pic. Regards George1 Building HMS SOTS
 Hi George I dont think you will have a problem as looking at the official build it looks the same for that rear former . Look at post#4 here http://forum.model-space...aspx?g=posts&t=5240
Looks like some carefull sanding on its way Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi George I dont think you will have a problem as looking at the official build it looks the same for that rear former . Look at post#4 here http://forum.model-space...aspx?g=posts&t=5240
Looks like some carefull sanding on its way Regards Andy Hi Andy. Looked at forum build your URL. It appears that in that case the angle piece was not glued on or if so only on bottom  No sanding off any angle left overs. I will nut it out like you explained re sanding and already have plans to use snips to cut first across on bottom then dremel head cut through angle till comes apart. Appreciate your input greatly. Regards George1 Building HMS SOTS
 Hi George Hindsite is a great teacher as is experience in building out little beautys. I think what I would do is this over trim the sides as per the official build, but the offending fomer at the back I would try to cut down its centre leaving a good chunk proud on the transom [ I know its a tall order but i think its going to be easyer triming back unwanted wood than the launch parts itself] so it can be sanded /trimmed back , as you will then have more room to get at it then Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi George Hindsite is a great teacher as is experience in building out little beautys. I think what I would do is this over trim the sides as per the official build, but the offending fomer at the back I would try to cut down its centre leaving a good chunk proud on the transom [ I know its a tall order but i think its going to be easyer triming back unwanted wood than the launch parts itself] so it can be sanded /trimmed back , as you will then have more room to get at it then Hi Andy Yes I agree with what you have suggested. Once off it won't be a problem so much regards sanding unwanted bits away. My razor saw is a joke as it grabs more than saws so will use sharp snips main areas to cut away then very carefully do that stern section. Again appreciate greatly your input. Regards George1 Building HMS SOTS
Have managed to separate without damage. Used snips then dremel head to cut angle piece away from stern. Next job sanding away unwanted material. Number 3 item at bow that was supposed to have no glue must have caught some runoff so will need to sand them away too.  Will shape stern later as per guiding line on rear.  Regards George1 Building HMS SOTS
Lovely work on the launch George, very fiddly job and I bet you find the main ship planking easier Steve
stevie_o wrote:Lovely work on the launch George, very fiddly job and I bet you find the main ship planking easier Steve Thanks Steve. Your comment appreciated greatly Yes Gandale also mentioned that ship planking he found easier so that's a big relief for me  Regards George1 Building HMS SOTS
you've achieved a good overall build george,very well done,careful trimming and sanding will produce a great mini boat to be proud of. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
karl1113 wrote:you've achieved a good overall build george,very well done,careful trimming and sanding will produce a great mini boat to be proud of. Hi karl Thanks for your comments. They are always appreciated. Regards George1 Building HMS SOTS
Joined: 27/02/2014 Posts: 149 Points: 456 Location: Forest Lake QLD
Hi George, Now I know why you have been a bit quiet lately. You've done well and should be pleased with the result  ! I found the first plank a bit more fiddly than expected mainly due to its thinness. I have still to add others which I will do later this week.
bb1949 wrote:Hi George, Now I know why you have been a bit quiet lately. You've done well and should be pleased with the result  ! I found the first plank a bit more fiddly than expected mainly due to its thinness. I have still to add others which I will do later this week. Hi Brex Yes that first plank is a bit fiddly. Just ensure you keep planks tight together as you add them. I found gluing just the end at the bow first then when stuck well enough to bring on across the ribs to the stern keeping the edges together as they naturally want to be slightly apart because of change of angle. Well we get our next issue today so will be klooking forward to some work to do. Regards George Building HMS SOTS
Issue 9 on to previous. Pieces in kit.  Rib frame dry fitted. Other section glued and put aside.  Regards George1 Building HMS SOTS
Joined: 25/04/2014 Posts: 374 Points: 1,134 Location: Mandurah W.Australia
Hi George I see you've got issue 9 in Perth. I went to the newsagent today Thursday as usual to get mine and was told it was not received this week. Will be available next week. Huh? Anyone else in WA with this problem? Regards JohnP
John Passmore wrote:Hi George I see you've got issue 9 in Perth. I went to the newsagent today Thursday as usual to get mine and was told it was not received this week. Will be available next week. Huh? Anyone else in WA with this problem? Regards JohnP Hi John This happened also back at issue 6 that didn't get to newsagents till the week after then we were one week behind from there. Some got a note with an issue to tell them in this regard from Gordon and Gotch. I didn't, neither did my newsagent. I hope that's not going to be the story again from what you have commented.  I was lucky then to have got issue 9. So going to be a mix up. Either you will get 9 and 10 next week or they'll do the same as last time and we'll all be waiting a further week for 10. This sort of going's on is not probably so bad once planking starts as old hands have said we would most likely be still working on one issue when the other arrives. However right now with issues that can be put together in one hour it's a real nuicence. Regards George Building HMS SOTS
Hi George
Yes...WA maintaining it's unblemished record of "Wait Awhile"
Regards JohnP
Joined: 16/03/2014 Posts: 64 Points: 172 Location: Buderim, Qld, Australia
Hi George, Saw your launch. Looks great. At what distance did you separate the two parts. Is there a measurement to saw by, or in your case snip by. I have been looking through builds and posts but have found nothing Regards Ted ______________________________________________________
Current Build: HMS Sovereign of the Sea
Joined: 08/03/2011 Posts: 65 Points: 187 Location: Bendigo Australia
Got issue 9 today or was that yesterday ;-) Previous builds Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour http://jockspage.webs.com/
Doing a great job George, well done on the launch it looks like it will sand down very nicely, just take care as the planks are very thin.... Regards Alan
