27 Pages «<56789>»
George1 Build Options
George1
#121 Posted : 07 May 2014 07:38:22
arpurchase wrote:
BigGrin Hi George
Looks a treat even with your misshaps you pulled it off
Hi Andy
Appreciate your comments greatly. Cool Cool
I'm glad it is done to that stage anyway. BigGrin
George1
Building HMS SOTS
George1
#122 Posted : 07 May 2014 07:44:00
I have a problem I can see happening when row boat cut from base. Where the stern is there is an angle piece that the stern fits against. This was glued to it as instructions, but now when I look at it the angle piece is actually higher than the black shaped line on stern when it is to be cut awayConfused
Any advice on this appreciated?Mellow
See Pic.
George1
Building HMS SOTS
#123 Posted : 07 May 2014 07:52:31
BigGrin Hi George
I dont think you will have a problem as looking at the official build it looks the same for that rear former . Look at post#4 here
http://forum.model-space...aspx?g=posts&t=5240
Looks like some carefull sanding on its way
George1
#124 Posted : 07 May 2014 08:01:21
arpurchase wrote:
BigGrin Hi George
Hi Andy.
Looked at forum build your URL.
It appears that in that case the angle piece was not glued on or if so only on bottomConfused No sanding off any angle left overs.
I will nut it out like you explained re sanding and already have plans to use snips to cut first across on bottom then dremel head cut through angle till comes apart. BigGrin
Appreciate your input greatly. Cool Cool
George1
Building HMS SOTS
#125 Posted : 07 May 2014 08:17:03
BigGrin Hi George
Hindsite is a great teacher as is experience in building out little beautys. I think what I would do is this over trim the sides as per the official build, but the offending fomer at the back I would try to cut down its centre leaving a good chunk proud on the transom [ I know its a tall order but i think its going to be easyer triming back unwanted wood than the launch parts itself] so it can be sanded /trimmed back , as you will then have more room to get at it then
George1
#126 Posted : 07 May 2014 08:23:57
arpurchase wrote:
BigGrin Hi George
Hi Andy
Yes I agree with what you have suggested. Once off it won't be a problem so much regards sanding unwanted bits away. My razor saw is a joke as it grabs more than saws so will use sharp snips main areas to cut away then very carefully do that stern section. BigGrin
Again appreciate greatly your input. Cool Cool
George1
Building HMS SOTS
George1
#127 Posted : 07 May 2014 09:19:20
Have managed to separate without damage.BigGrin
Used snips then dremel head to cut angle piece away from stern.
Next job sanding away unwanted material. Number 3 item at bow that was supposed to have no glue must have caught some runoff so will need to sand them away too.BigGrin
Will shape stern later as per guiding line on rear. BigGrin
George1
Building HMS SOTS
#128 Posted : 07 May 2014 09:23:21
George1
#129 Posted : 07 May 2014 09:29:36
stevie_o wrote:
Lovely work on the launch George, very fiddly job and I bet you find the main ship planking easierBigGrin
Thanks Steve.BigGrin
Your comment appreciated greatly Cool Cool
Yes Gandale also mentioned that ship planking he found easier so that's a big relief for me Laugh
George1
Building HMS SOTS
#130 Posted : 07 May 2014 11:02:36
you've achieved a good overall build george,very well done,careful trimming and sanding will produce a great mini boat to be proud of.
George1
#131 Posted : 07 May 2014 13:57:28
Hi karl
Thanks for your comments. They are always appreciated.Cool Cool
George1
Building HMS SOTS
bb1949
#132 Posted : 07 May 2014 13:59:20
Hi George, Now I know why you have been a bit quiet lately. You've done well and should be pleased with the resultCool! I found the first plank a bit more fiddly than expected mainly due to its thinness. I have still to add others which I will do later this week.
George1
#133 Posted : 08 May 2014 02:34:27
Hi Brex
Yes that first plank is a bit fiddly. Just ensure you keep planks tight together as you add them. I found gluing just the end at the bow first then when stuck well enough to bring on across the ribs to the stern keeping the edges together as they naturally want to be slightly apart because of change of angle. BigGrin
Well we get our next issue today so will be klooking forward to some work to do. BigGrin
George
Building HMS SOTS
George1
#134 Posted : 08 May 2014 08:00:06
Issue 9 on to previous.
Pieces in kit.
Rib frame dry fitted. Other section glued and put aside.BigGrin
George1
Building HMS SOTS
John Passmore
#135 Posted : 08 May 2014 09:13:48
Hi George
I see you've got issue 9 in Perth. I went to the newsagent today Thursday as usual to get mine and was told it was not received this week. Will be available next week. Huh?Huh Confused
Anyone else in WA with this problem?
JohnP
George1
#136 Posted : 08 May 2014 10:36:23
John Passmore wrote:
Hi George
JohnP
Hi John
This happened also back at issue 6 that didn't get to newsagents till the week after then we were one week behind from there. Some got a note with an issue to tell them in this regard from Gordon and Gotch. I didn't, neither did my newsagent.
I hope that's not going to be the story again from what you have commented. Mad
I was lucky then to have got issue 9.Blink
So going to be a mix up. Either you will get 9 and 10 next week or they'll do the same as last time and we'll all be waiting a further week for 10.Cursing
This sort of going's on is not probably so bad once planking starts as old hands have said we would most likely be still working on one issue when the other arrives. However right now with issues that can be put together in one hour it's a real nuicence. Angry
George
Building HMS SOTS
John Passmore
#137 Posted : 08 May 2014 13:37:00
Hi George
Yes...WA maintaining it's unblemished record of "Wait Awhile"
JohnP
Tanna Ted
#138 Posted : 08 May 2014 14:17:53
Hi George,
Saw your launch. Looks great. BigGrin
At what distance did you separate the two parts. Is there a measurement to saw by, or in your case snip by. I have been looking through builds and posts but have found nothingConfused
Ted
______________________________________________________
Current Build: HMS Sovereign of the Sea
jock
#139 Posted : 08 May 2014 16:27:15
Got issue 9 today or was that yesterday ;-)
Previous builds
Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour
http://jockspage.webs.com/
#140 Posted : 08 May 2014 23:26:51
Doing a great job George, well done on the launch it looks like it will sand down very nicely, just take care as the planks are very thin....Cool Cool
Guest (5)
27 Pages «<56789>»
This page was generated in 0.238 seconds.
