When building the MP 4/23 there was a screw guide in the magazine depicting letter of screw and size. Are we using the same screws on the MP 4/4 build ?
Hi Al To answer your question I would say that it is likely that some screws maybe similar to the MP4/23 but that does not necessarily mean they will all be the same, plus there maybe additional sizes/types within the Senna build. When you recieve your packs you will be supplied additional screws (so if you need 4 screws then you may get 5 of that type) with each stage just incase you lose one. I suggest you put any spare ones aside incase you need them later in the build. In pack 2 there is a guide on some of the screw types used and how to identify them... Regards Spencer Warthog attached the following image(s):
thats what im after  makes life a bit easier when using a multitude of screws
Joined: 20/12/2012 Posts: 17 Points: 51 Location: Essex, UK
Great question! Great answer!
I'm sincerely happy about having a guide for the MP4/4 - that was the biggest hassle as far as I'm concerned when building the James Bond Aston Martin DB5. I even ran out of a certain screw type toward the end and had to get some replacements from the publisher.
Thanks for putting my mind at rest. DeAgostini ModelSpace Mitsubishi A6M2b Zero DeAgostini ModelSpace Senna MP4/4
