John Passmore Options
John Passmore
#1 Posted : 05 May 2014 05:43:40
G'day George
I've noticed references to Dremel tools in various threads. Do you have one?
If so, are there various models? Can you tell me what model is most appropriate for this kind of work? I've never used one before so all this intrigues me no end. My career was spent mostly in heavy engineering and construction (power stations), so this is the other end of the scale!BigGrin
Advice would be very much appreciated.
JohnP
bb1949
#2 Posted : 05 May 2014 14:08:08
Hi John,
Dremel is a brand name for a very high speed hand held drill, engraver grinder tool etc suited for hobbyists. I have the Ozito brand which is cheaper and operates well enough for me but can be low on torque. I have connected an extension cable to my power plant and the finishing hand which you can see in the photo. Both brands are available at Bunnings but prices are different. I bought mine on the basis of price. If it dies (and the extension cable did three years ago)then it is cheaper for me to buy a whole new Ozito unit (as you also get lots of consumables) so I am ok replacing every so often. I believe the Dremel will last you longer but I have no experience to confirm that.BigGrin
bb1949 attached the following image(s):
John Passmore
#3 Posted : 05 May 2014 23:55:03
bb1949 wrote:
Hi John,
Hi BB
Thanks for the info - much appreciated.
I'll go and check it out today. Being OAP I have to watch the pennies.BigGrin
JohnP
AdamHall
#4 Posted : 06 May 2014 03:07:07
John,
I have a Dremel with an extension cable attachment that I purchased as an addition. I found that the Dremel without the extension tended to be slightly top heavy, especially for fine work. I just need to be carefull that the extension cable is neatly flaked out on the workbench as the torque from the Dremel (especially when you dial in higher RPM) tended to want to try and straighten up and want to make the Dremel itself move about. There is a warning about this in the brochure and a recommendation to mount the Drememl in a stand. I don't have the stand as yet, mainly due to infrequent use and I am saving pennies to get one eventually. Other than that, there are no problems.
At the end of the day it comes down to horses for courses, how often you are going to use it, what feels right in your hand when it is operating, what other additional attachments are supplied in the kit and cost.
Adam
#5 Posted : 02 June 2014 21:41:31
In my honest opinion Proxxon are much better
http://www.proxxon-direct.com
I have the the FBS 240 E with flexible attachment and keyless chuck its beyond superlatives BigGrin
John Passmore
#6 Posted : 03 June 2014 08:42:31
Hi Jase
Thanks for the info, but I don't think Proxxon are avail in OZ and I don't
want the hassle of procurement from UK.
Cheers
JohnP
This page was generated in 0.181 seconds.
