Screw guide Options
#1 Posted : 02 May 2014 17:15:58
Rank: Amateur level 2
When building the MP 4/23 there was a screw guide in the magazine depicting letter of screw and size. Are we using the same screws on the MP 4/4 build ?
#2 Posted : 02 May 2014 20:03:29
Hi Al
To answer your question I would say that it is likely that some screws maybe similar to the MP4/23 but that does not necessarily mean they will all be the same, plus there maybe additional sizes/types within the Senna build. When you recieve your packs you will be supplied additional screws (so if you need 4 screws then you may get 5 of that type) with each stage just incase you lose one. I suggest you put any spare ones aside incase you need them later in the build.
In pack 2 there is a guide on some of the screw types used and how to identify them...
Spencer
#3 Posted : 05 May 2014 20:55:40
thats what im after BigGrin makes life a bit easier when using a multitude of screws
Arrow Wolf
#4 Posted : 12 May 2014 15:18:14
Great question! Great answer!
I'm sincerely happy about having a guide for the MP4/4 - that was the biggest hassle as far as I'm concerned when building the James Bond Aston Martin DB5. I even ran out of a certain screw type toward the end and had to get some replacements from the publisher.
Thanks for putting my mind at rest.
DeAgostini ModelSpace Mitsubishi A6M2b Zero
DeAgostini ModelSpace Senna MP4/4
This page was generated in 0.161 seconds.
