Using shaping tool Options
joewb10
#1 Posted : 30 April 2014 21:30:46
Has anyone tried using the shaping tool in issue 74?
I'm finding it pretty useless in terms of removing wood. Or is there some knack to using it.
I'm thinking of making up strip lengths from separate pieces of wood.
#2 Posted : 30 April 2014 23:29:02
hi there, yep I found it works a treat, just draw it towards you at an angle of 45 degrees for about 50-100 times,and it shapes really well,good luck, k.
#3 Posted : 30 April 2014 23:44:15
Hi there, I found it to be pretty good once I got the hang of how to use it..... Found you have to draw it across the wood at an angle, the angle should be in the direction you are moving plus a fair amount of pressure needs to be applied......
This page was generated in 0.083 seconds.
