Joined: 25/04/2013 Posts: 71 Points: 216 Location: Benoni, South Africa
Seem to be doing the gunports quite quickly. Although some of the sides are not as straight as they should be, I can file these down when putting in the little planks inside the gunports. Thanks for all your comments and help. cuandv attached the following image(s): Current Build: HMS SOTS HMS Victory HMS Surprise
Your gunports are coming along well, very neat work Steve
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Looking very smart, keep up the great work. Regards Foz
Very nice looking build. Look forward to seeing your progress Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 21/01/2014 Posts: 1 Points: 3 Location: Georgia
stevie_o wrote:Hi Cuan The second layer will certainly be easier due to the fact that you will not need to bend any planks, easier to lay as well as you have a solid base to work on rather than just bulkheads. It's also a chance to hide any imperfections (not that I can see any) - Is the veneer supplied as 2 colour effect as well? Steve I have an open question on this matter: Does anybody do a build and actually deface (add dents and marks) the planking to make the the sides look more realistic? Mo
With the wood that came with the DelPrado, there was no need to 'add' anything! Just joking! some of it was ok! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Joined: 01/04/2013 Posts: 342 Points: 1,029 Location: Essex
Plymouth57 wrote:With the wood that came with the DelPrado, there was no need to 'add' anything! Just joking! some of it was ok! Robin Nice one Robin,probably only another Del Prado builder would appreciate the cutting edge of the humour. Back to the topic, Cuan, I haven't seen it done to the hull,but doesn't mean you can't do it, would be different, but has to be your call. As its been said many times on this forum, go with what you are happy with. Regards Alan England expects that every man will do his duty.
[size=7]Hi, I need some HELP. Does the transom (#30) go up at an angle, and if so how much? IS the edge of the transom supposed to be flush with (#16) or is it supposed to hang a little over the edge of #16. It looks (in the plans) like they are flush. Please any help would be greatly appreciated.
Hi Odenjs, Sorry for very late reply on this. I have made mine go 2mm over the top just in case. Its always easier to sand away than to add back later. Cheers Cuan Current Build: HMS SOTS HMS Victory HMS Surprise
Guys, I am building 2 ships at the same time so I do some on the victory and some on the SOTS. Back onto the Victory now so more updates coming. I have started the gunport linings and can I just say...What a painful experience. Putting in little pieces of wood on the side of each gunport and then they fall into the ship etc and then trying to retrieve them again.....Shoo! Anyway, I will post some pics on the status. Please let me know your thoughts. I see that when putting the gunport linings on looks quite strange as they tick out a little, but when sanding them, they start to blend in nicely with the side of the ship. Cheers Cuan cuandv attached the following image(s): Current Build: HMS SOTS HMS Victory HMS Surprise
Hi Cuan She's coming along really well there!  I can remember just how fiddly the gun port frames were on my Grimsby! It looks like you might already be doing it, but I found it easiest to cut and glue the top and bottom edges in first and when they were dry cut and fit the side pieces, there was less 'slippage' inside that way! You're doing great so far! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Beautiful work Cuan, the wood contrast is very nice Steve
Very nice looking build Cuan, think this will end up being a beautiful build..... very well done.... Regards Alan
Mooi so Cuan, she's looking great, shows you what time and effort can do. Well done. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Adding the wales on the side of ship and am putting in the gallery at the back etc. Lots of finishing to do but we go on.... cuandv attached the following image(s): Current Build: HMS SOTS HMS Victory HMS Surprise
I am really enjoying watching this build come together Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Lovely build, you should be very proud of this one. Steve
Hi Cuan. Looking very Nice. Look forward to seeing more of your build. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks everyone. I have made a few beggar-ups, being my first ship. I think a lesson learn here is that using a fair amount of force doesn't particularly help the cause I will keep this updated as I go Current Build: HMS SOTS HMS Victory HMS Surprise
