jock Options
jock
#1 Posted : 21 April 2014 09:04:42
Just a small question, how long is the bowsprit from the stem. I'm building a protective box (cat proof)
Previous builds
Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour
http://jockspage.webs.com/
#2 Posted : 21 April 2014 09:14:13
Hi Jock, according to instructions Length: 1100mm, Height: 900mm, Beam: 400mm
jock
#3 Posted : 21 April 2014 10:18:54
What I'm after is the distance from the stem to the tip of the bowsprit
Previous builds
#4 Posted : 21 April 2014 10:28:14
Hi Jock, its 1100mm from stern to bowsprit tip.... This may help... http://forum.model-space...aspx?g=posts&t=4725
jock
#5 Posted : 21 April 2014 10:35:17
Sorry Guys it's the distance from the STEM not the stern,senior momentBlushing
Previous builds
#6 Posted : 21 April 2014 12:27:05
Hi Jock, that dimension is probably an unknown as I don't think anyone has recieved the bowsprit plans as yet - you could "guestimate" by subtracting the hull length from the total length? Surely though if you are wanting the info to build a box for display then the total length should be what you need?Confused (unless I'm missing something)...
#7 Posted : 21 April 2014 12:35:27
Hi Jock, the bowsprit is 325mm long and you will have to add some extra for the overhang of the fighting top.... Cool Cool ..
Hope this helps...
This page was generated in 0.100 seconds.
