 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 08/03/2011 Posts: 65 Points: 187 Location: Bendigo Australia
Just a small question, how long is the bowsprit from the stem. I'm building a protective box (cat proof) Previous builds Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour http://jockspage.webs.com/
jock wrote:Just a small question, how long is the bowsprit from the stem. I'm building a protective box (cat proof) Hi Jock, according to instructions Length: 1100mm, Height: 900mm, Beam: 400mm Regards Alan
What I'm after is the distance from the stem to the tip of the bowsprit Previous builds Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour http://jockspage.webs.com/
jock wrote:What I'm after is the distance from the stem to the tip of the bowsprit Hi Jock, its 1100mm from stern to bowsprit tip.... This may help... http://forum.model-space...aspx?g=posts&t=4725
Regards Alan
Sorry Guys it's the distance from the STEM not the stern,senior moment Previous builds Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour http://jockspage.webs.com/
Hi Jock, that dimension is probably an unknown as I don't think anyone has recieved the bowsprit plans as yet - you could "guestimate" by subtracting the hull length from the total length? Surely though if you are wanting the info to build a box for display then the total length should be what you need?  (unless I'm missing something)... Steve
Hi Jock, the bowsprit is 325mm long and you will have to add some extra for the overhang of the fighting top....  .. Hope this helps... Regards Alan
