CMB VICTORY BUILD Options
CMB
#1 Posted : 26 July 2010 18:52:47
At long last I think I have worked out how to insert my pictures.
So here goes with my build diary to date.
Like many of you I have returned to model building after many years and am finding it most enjoyable. My launch has been rebuilt several times and the planking repaired and filled more times than I care to admit but now am at the stage of fitting the internal boards and fittings.I will try to add pictures in my next update.
amipal
#2 Posted : 27 July 2010 00:01:53
Nice, looking forward to the pics! Cool
CMB
#3 Posted : 04 August 2010 22:38:06
At long last the launch is taking shape and looking like it may be OK after all.
I made a basic error in assuming that the "precision cut laser parts" would fit together without any modification required, I now know better.
Having eventually sorting out the hull planking and oar slots, I fitted the floor boards, mesh inserts and thwarts. Now realize that I have not fitted the brass strip to the first and 5th thwart as I am awaiting delivery of the round nose pliers from eBay. I should have these by the weekend and will fit both in situ (I hope)
As you can see I have started to paint the outside of the hull and again hope to complete this weekend. Then on to the windlass, transom supports, eyebolt and rudder. Painting the oars should not be too difficult but I am a little apprehensive regarding the mast, but we shall see.
Below a selection of pictures of the build to date.
Sorry if the pics are to big, still trying to sort out the best way to upload them.
The paint finish looks awful but is not that bad in the flesh.
Hi All,
I have been busy building and here are the latest results of the main hull to date, the launch is also undergoing some rectification work and should be ready soon.
Any comments welcome but nothing to harsh as it is my first attempt.
Happy building to you all
CMB[biggrin
CMB attached the following image(s):
Zeptrader
#4 Posted : 04 August 2010 23:06:06
welcome and a great start, keep 'em coming BigGrin
Sundance
#5 Posted : 04 August 2010 23:44:22
How the hell do you get black paint to stick to the grills? I'm using the official goauch paints for the build but no luck, it just seeps thro and doesn't dry.
CMB
#6 Posted : 05 August 2010 00:17:17
I used acrylic grey metal primer thined down so as not to fill in the mesh and the brush was almost dry.It took 2/3 coats then applied the black paint from the Victory set, again the brush was almost dry and applied 2/3 coats.As a point of interest I added 3ml water to the bottle of black paint and this thined it down nicely, also used the same method to the white and ochre paint. Paint still dries very quickly.
Hope this helps
CMB
Mike Turpin
#7 Posted : 05 August 2010 08:45:25
Which grey primer did you use and where did you get it from.? I assume that it wasn't a spray as you mentioned using brush.
Cheers
MikeT
#8 Posted : 05 August 2010 08:59:52
mike cornwall models do it in the admiral range metal primer that is.
Mike Turpin
#9 Posted : 05 August 2010 09:18:53
Cheers Karl
I don't know how many times I've searched the Cornwall site and missed that one!!!
I feel an order coming on! -- trouble is it won't stop at the one item!
Mike T
CMB
#10 Posted : 05 August 2010 10:06:39
Cheers
MikeT
I used PolyVine acrylic enamel paint purchased from Homebase.
50ml bottle cost £2.59.Ref.Number on bottle cap 47.
A range of colours available
Boaz
#11 Posted : 05 August 2010 15:47:31
Scull White & Chaos Black from Games Workshop are pretty spot on as primers.
Stedders is the Paint God.
Pray to him in the forum & he will light up your path.LOL
Bob
gaffa1963
#12 Posted : 05 August 2010 17:14:24
Rank: Amateur level 2
I used the skull white from games workshop sprayed paint onto paper then used a brush to paint
the mesh boards
CMB
#13 Posted : 22 October 2010 20:40:05
Hi All,
CMB[biggrin
CMB
#14 Posted : 20 May 2015 15:17:50
Help wanted.
I am about to recommence my Victory build after some 6 months due to some serious surgery and appear to have mislaid/lost the black netting for making the hammock nets.
Has anyone any spare netting, I am willing to pay postage ect.
CMB
#15 Posted : 20 May 2015 18:16:34
Hi CMB.
Nice to see your back on your build. Look forward to seeing your progress Ian.Cool BigGrin
#16 Posted : 20 May 2015 18:33:56
Hi CMB, great to see you back again and hope all the medicals go well! BigGrin
If you have a market near you with any dressmaking shops or stalls check them out - you can buy very similar nylon netting by the yard for mere pennies. If you check out my DelPrado Victory diary you can see it in use.
Note though, I mistakenly bought black without realising the real netting is natural rope, not tarred! If you can get a tan or light grey colour you can save having to paint it like me!
Hope that helps
Robin
CMB
#17 Posted : 21 May 2015 10:36:43
Hi Robin,
Thanks for you good wishes.
Many thanks for the tip.
Will visit local store over the weekend and have a look.
Cheers
CMB
CMB
#18 Posted : 21 May 2015 10:38:45
ian smith wrote:
Hi CMB.
Hi Ian,
New pictures will be posted soon.
CMB
Hans
#19 Posted : 21 May 2015 11:39:34
Hello CMB. welcome back to the fold. Looking forward to seeing some more of your pics.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#20 Posted : 27 May 2015 08:38:05
Hi CMB,
Welcome back. Glad to hear that you are on the mend. Looking forward to following your progress.
This page was generated in 0.202 seconds.
