cal Options
cal
#1 Posted : 16 April 2014 21:27:58
How late in the build can I attach the bow spirit lack of space will make it difficult to turn round Cool
#2 Posted : 16 April 2014 21:44:58
Hi Cal
Well it's lashed in at issue 93 but I guess you could leave it it a little later, probably will need it permanently in place by issue 96 though as this is where the stays are attached. At least you will be able to get all the shrouds done and all the hammock netting before you attach itBigGrin
Once you get used to it in place you will make allowances for it, it's just the first couple of days when your knocking it each time you turn it.
cal
#3 Posted : 16 April 2014 22:00:56
Im on with issue 92 at moment so that gives me a bit more time thanks steveBigGrin
This page was generated in 0.084 seconds.
