14 Pages «<11121314>
sandnesspeats Options
GluedFingers
#241 Posted : 11 April 2014 18:21:02
That's a great tip, Steve! ThumpUp ThumpUp ThumpUp ThumpUp
I think I'm going to nab that one for the Surprise, thank you very much!LOL LOL LOL
Adrie
sandnesspeats
#242 Posted : 12 April 2014 10:21:27
hi,
thanks for the great tips, The tape I used was good, I think I never pressed it down enoughBlushing .
I should have asked before I done it, That tip Steve was great, I will touch it up a bit, I hope I have enough paintBigGrin BigGrin .
thanks again for the advice.
rob
z8000783
#243 Posted : 12 April 2014 10:28:12
Groups: Unapproved
That is a gorgeous hull, Rob.
#244 Posted : 12 April 2014 10:53:38
Adrie
I would recommend you do a trial first on some scrap. If your not carful you can get to much build up of paint which can result in you having a ridge.
As always when trying something new experiment with it firstBigGrin
#245 Posted : 12 April 2014 11:01:35
Hi
I will point out that the second yellow coat is just a quick brush over to seal the tape. The method works fine and I used it on my Vic build and can see no visible ridge where the two colours meet-
http://forum.model-space...osts&t=6074&p=2
You can also use a matt varnish instead of the yellow to seal the tape.
But, as Jase suggested, if you have doubts you could also have a practice on some scrap wood before trying on the VicBigGrin
sandnesspeats
#246 Posted : 12 April 2014 11:27:15
Thanks for that, Another thing is that I wish I had left off the wriggles before I paintedAngry
cheers
BigGrin
#247 Posted : 12 April 2014 11:31:32
I know what you mean about the wriggles, I painted my Vic stripes way earlier than the mags say to. I did it when I had a nice clean hull with no obstructions for the masking. There were many cases of re-touching later though but I though this was an easier way for me.
sandnesspeats
#248 Posted : 12 April 2014 12:12:17
hi steve,
I just never realised what involved in painting,as it is my first build after all. There are a lot of instances in the magazine where some things should have been done at different stages etc., but not knowing what to expect what do you do. I am not complainingMellow like the masts for example, it might have been better done after the hull was finished. I am still enjoying the build after all said and done.
Great hobby to do.BigGrin BigGrin even better when I get all the advice I have had, I presume I am not the only one. BigGrin BigGrin
Thanks again
rob
ps. just had a look at your great build and seen there were no wriggles when you painted. OH! hindsight again.BigGrin BigGrin
sandnesspeats
#249 Posted : 12 April 2014 23:13:59
Hi again,
has any body any better ideas for putting the wire around these deadeyes Issue 75 page 12. I am finding it a nightmare Cursing Cursing
just a thought.
thanksBigGrin BigGrin
rob
#250 Posted : 13 April 2014 00:57:58
Hi Pete
I did see some other ways to do this but I used the mag / official build way and found it to be fine, not easy I admit and a bit repetitive but take your time and it will be okBigGrin, you may even work out another method while you are doing it.
sandnesspeats
#251 Posted : 13 April 2014 11:53:45
Hi steve,
I have done 4 of them, lost two,just pinged out of my fingersCursing BigGrin if there are no spares I will have to order a back issue Mellow. Fingers are a bit big to grab the little Angry Angry LOL LOL ....
Just have to take my time as you say.BigGrin
cheers mate
rob
#252 Posted : 13 April 2014 12:39:46
You may need to find those deadeyes again as there are not many spares supplied.
No need to order back issues though - http://www.cornwallmodel...artesania-deadeyes.html
I will say one thing I did though was to use black coated wire of a slightly thinner gauge. The reason for this is that I wanted the deadeyes black as per the the real Victory and this saved painting the wire, easier to twist also so maybe that's why I had no real troubleLaugh
sandnesspeats
#253 Posted : 13 April 2014 12:50:31
Thanks again steve I will have another look if not I will try that link. I did try to order some stuff from them but they wanted £20 postage. I will phone them if I cannot find the other ones.
thanks again.
ps.Where did you get the wire from???
cheers
#254 Posted : 13 April 2014 12:59:38
sandnesspeats
#255 Posted : 13 April 2014 14:22:23
hi steve just ordered some of the same size thanks.
I managed to find the two I lost, very lucky I have to admit.BigGrin BigGrin
cheers for all your help
rob
#256 Posted : 13 April 2014 14:29:02
sandnesspeats
#257 Posted : 13 April 2014 14:33:37
Never thought about it really but I expect it should be black,will have to paint them I supposeBigGrin BigGrin.
cheers
rob
#258 Posted : 13 April 2014 14:37:16
I only noticed on the off chance that the real ones are black so that's what I did.
Make a little board with some inverted masking tape, stick them all down and spray them, then turn them over, easy!BigGrin
sandnesspeats
#259 Posted : 13 April 2014 16:45:16
That`s what I like to hear as I sprayed the hull which came out ok as you say, easy.BigGrin BigGrin I will do that with the dead-eyes Cool
thanks mate
rob
sandnesspeats
#260 Posted : 05 April 2015 16:33:20
Hi Folks, back again,at last, just never had much chance on my boat over the last months. Scrounging for info again.
Anyway, I am on 83. I am about to glue the acetate etc, It says to use clear glue as superglue is not suitable,
could any shed light on this as this is my first build things just pop up for me to buy or ask etc.
Which glue to use etc.
just put the cannon port lids on as you can see,does not look too bad.
thanks for any info.
sandnesspeats attached the following image(s):
This page was generated in 0.207 seconds.
