rope ladders Options
steviegio
#1 Posted : 06 January 2014 13:00:47
Rank: Beginner Level 3
Hi Guys
I have just decided to remove all the rope ladders from the yards as I was not happy with the finish. Has anyone found a better and more authentic way of doing these
#2 Posted : 06 January 2014 13:45:24
This may help?
http://forum.model-space....aspx?g=posts&t=932
#3 Posted : 06 January 2014 15:42:22
#4 Posted : 06 January 2014 23:13:14
Don't know if you have seen this but it may help...
http://forum.model-space...aspx?g=posts&t=9083
#5 Posted : 07 January 2014 14:44:47
stevie_o wrote:
I wouldnt mind taking a look at this either but there are no pics showing.
Sorry I took it of my list of 'hot lincs' so did not check the content.
steviegio
#6 Posted : 11 April 2014 18:12:22
sorry Im confused. I was referring to the small rope foot holds made from brass wire that hang from the yards. Mine just don't look authentic so I wondered if one of you clever folks had found a better way of t]doing this
#7 Posted : 11 April 2014 18:21:36
Hi
You could just use the natural thread, twist it just like the brass wire making sure you retain a loop in the end and then either use some watered pva or thin CA to seal the twist in place. You would have to devise a way to keep it taught while the glue dried though especially in the case of the pva.
#8 Posted : 11 April 2014 18:46:46
hi steve, you mean the stirrups and the horses,I made mine using .75mm brass wire,and making a ring one end,(like a long eyebolt, )making them 20mm. long, then drilling the yard at suitable spaces, then threading them after installing them. good luck.
