19 Pages «<7891011>»
My Build Diary of the Santisima Trinidad Options
#161 Posted : 07 April 2014 23:16:47
Worth all the effort Andy, lovely job.....Cool Cool
#162 Posted : 07 April 2014 23:46:10
BigGrin Hi Ian
#163 Posted : 07 April 2014 23:46:52
BigGrin Hi Alan
#164 Posted : 24 April 2014 19:43:24
Hi Andy,
Have you decided yet if you are going for a natural build or a painted one, I'm thinking of painting the Trafalgar colours but I understand there is some nice hardwood supplied with this kit which may look nice with a bit of varnish.
#165 Posted : 24 April 2014 20:15:14
BigGrin Hi Steve
You are right about the nice hardwoods for the hull and will be starting the secondary planking in the next issue. As for a finish im leaning more towards a natural finish with perhaps the use of drawing inks to stain where needed. All this of course will hinge on the finish I can get on the hull but we will see.
If you go for the painted version then it will be a nice contrast between the two builds.
#166 Posted : 24 April 2014 20:26:27
I was thinking the same Andy, Think I'll paint then so we can have 2 finishes on here. I'm going for the red/white/black with copper hull, I think the masts are left natural anyway.
#167 Posted : 04 May 2014 20:29:06
BigGrin Hi All
This month its the start of the secondary planking but before that was applied I painted all the lower gun port holes matt black as doing it beforehand prevents it getting on the second set of planks. The transom was the 1st part to be done and then two layers of the hull planks were added , soak the planks where they curve around the transom to prevent splitting . Slow work but pays dividends getting the planks aligned correctly at this stage.
#168 Posted : 04 May 2014 20:36:19
Andy, Cool
That hull looks great.Drool Drool
WTG
Happy building
#169 Posted : 04 May 2014 22:05:54
Hi Andy
Looks good what wood are you using for second planking.
Trev
#170 Posted : 04 May 2014 23:19:31
Looking good....Cool
#171 Posted : 05 May 2014 08:35:22
BigGrin Hi Del
#172 Posted : 05 May 2014 08:38:46
BigGrin Hi Trev
Thanks for looking in and your comments. AS for the wood used so far I think the upper light planks are Lime wood and the lower planking will be of a mahogany. There is I plethora of nice hard woods in this kit and its a little gem to build.
#173 Posted : 05 May 2014 08:39:21
BigGrin Hi Alan thanks for looking inCool
#174 Posted : 05 May 2014 17:35:14
BigGrin Hi All
Added more upper planking today about half way up now, I also added one of the lower hardwood planks to show the contrast between the two.
More soon
#175 Posted : 05 May 2014 21:50:22
Coming along nicely Andy.... Cool
#176 Posted : 05 May 2014 23:24:19
#177 Posted : 06 May 2014 08:03:40
BigGrin Hi Steve
Thanks for your comments and looking in
#178 Posted : 08 May 2014 20:50:11
BigGrin Hi All
The upper hull planking has now been completed apart from a couple of fillets at the bow, next is to carry on with the hardwood lower hull then start adding more deck furniture.
More soon
#179 Posted : 08 May 2014 21:22:05
coming on a real treat andy,mouth watering.Cool
#180 Posted : 09 May 2014 21:13:10
BigGrin Hi Karl
This page was generated in 0.350 seconds.
