Which drill to use for small drill bits Options
JC
#1 Posted : 08 March 2014 11:05:35
Rank: Newbie
I am building the Caldercraft Victory and have a problem in drilling the small 0.5mm holes required (looks like hundreds of holes will be require so it will be worth getting the right gadget to do a good job).
I have a 'cheap' 12volt drill which seems a bit too powerful - in starting to drill the drill bit 'bounces' and does not bite into the wood immediatly
Tempted to try a Archimedean Drill Stock
http://www.cornwallmodel...uk/acatalog/dr1411.html
Any hints please??
Currently a month into the build and have just started the copper tiles - 'great' fun looking forward to finishing them in a week (or twos??) time
Thanks in advance
Julian
#2 Posted : 08 March 2014 11:13:04
Hi Julian,
An Archimedes pin vice drill is a valuable piece of any builders arsenal of tools and one that will serve you well for this purpose.
Spencer
GilShapley
#3 Posted : 08 March 2014 11:52:57
Hi Julian
You may also like to try the Pin Vice. I found them easier to use/control when drilling numerous holes in my Victory. about the same price as the Archimedes.
One thing to note there is an additional chuck "hidden" in the handle. Took me weeks to accidentally discover this when changing drill bits one day. The handle came appart and bingo an additional chuck stored in the handle.
Confused Confused Confused Confused Confused Confused
Current Build:-
#4 Posted : 08 March 2014 15:21:01
one hint and tip I keep giving,is the drills are expensive and break easily, use dress makers pins,cut of the head and the cut end is the the drilling end,saves a fortune.works with a power drill and pin vices.
George1
#5 Posted : 24 March 2014 02:48:05
Hi karl1113
Thanks. Another great tip that I'll be taking on board.BigGrin
Lot cheaper than drill bits.
George1
Building HMS SOTS
#6 Posted : 24 March 2014 08:09:49
Karl your a geniusCool
JC
#7 Posted : 30 March 2014 16:07:44
Rank: Newbie
Got the archimedes drill - it works a treat - thanks for the help
Julian
Guest (5)
This page was generated in 0.473 seconds.
