16 Pages «<89101112>»
ARPurchase's build of the D51 Options
court orchard
#181 Posted : 23 March 2014 09:17:10
Hi Andy,
That Backhead is spot on, top marksThumpUp
#182 Posted : 23 March 2014 10:16:50
BigGrin Hi Andy
Thanks for looking in and your comments , much appreciated
bluedot0
#183 Posted : 09 April 2014 01:57:13
Rank: Amateur level 2
Hi Andy
Brilliant job as usual, can you tell me what your using as an undercoat, thanks.
Phil
You only live once, but if you work it right, once is enough.
Building - Bismarck, Akagi, Warspite, Gato, USS Enterprise (carrier) and D51
experten
#184 Posted : 09 April 2014 05:36:22
Andy, the loco is looking fantastic! I am almost second guessing my choice to do mine in brass.
Tired, Old, and Cranky!
#185 Posted : 09 April 2014 17:04:20
BigGrin Hi Phil
I generally use a product called Canbrush, primer surfacer grey C5 , I have added a link to flea-bay but this is just to show the product as I generally pay around £3.00 per can over here. If you have ever used any of the Plasticote range of paints it gives a similar finish for a lot less and is good for wood metal and plastic. Hope this helps
#186 Posted : 09 April 2014 17:05:13
BigGrin Hi Mark
bluedot0
#187 Posted : 10 April 2014 01:16:48
Hi Andy
Thanks for your responseBigGrin, I was just curious as to whether it was an etch primer or a surface primer. I know what you get over there, is generally something totally different here. However, I bought a surface primer and some thinner this morning from the local auto shop.
As far as the black top coat goes....I found a friendly and somewhat curious spray painter who is mixing a weathered black for the top coat for me at his shop....be interesting to see how it looks.
Phil
#188 Posted : 10 April 2014 21:35:38
BigGrin Hi Phil
I forgot to mention use a good degreaser on everything as it is use con all the parts for protection and nice find for the paint hope it works out
bluedot0
#189 Posted : 11 April 2014 06:05:42
Hi Andy
Thanks for that, I suspected you would have used a degreaser....I was considering a short bath in some white vinegar before applying the undercoat. A few sites in the US I've looked at suggest it.....so I'll test a few scraps I have first.
Phil
#190 Posted : 13 April 2014 15:57:11
BigGrin Hi All
This month its add the other running board the compressor, some smaller fittings and the forward running board made up ages ago. Please note the boiler is only sitting on the running gear and this thing is starting to get seriously heavy.
More soon
#191 Posted : 13 April 2014 17:08:27
I was just about to say that must weigh a ton! Looking fab Andy Cool
Spencer
#192 Posted : 13 April 2014 18:11:05
#193 Posted : 13 April 2014 19:47:15
BigGrin Thanks Steve and Spencer for your commentsCool
#194 Posted : 13 April 2014 19:53:22
Hi Andy, BigGrin
I`m no train buff, but that looks Good,
Cool Drool Cool Drool Cool Drool Cool
#195 Posted : 13 April 2014 19:58:50
BigGrin Hi Del
#196 Posted : 13 April 2014 23:52:31
Lovely work Andy and considering the build is nearly all brass then am not surprised she is now some weight....Cool Cool ..Nicely done...
bluedot0
#197 Posted : 14 April 2014 01:07:01
Hi Andy
Well done...she's looking really good.
Phil
#198 Posted : 14 April 2014 20:05:54
BigGrin Hi Alan
Thanks as always for your comments
#199 Posted : 14 April 2014 20:07:38
BigGrin Hi Phil
thanks for looking in and your comments
#200 Posted : 18 May 2014 17:47:53
BigGrin Hi All
This month its more pumps and air cylinders to add these have been painted and attached to the engine.
The first parts of the cabin have arrived also, here I didn't think using glue to join the top members to the cabin was a good idea as butt joints are never strong in general and o good knock will split it apart, so I have soldered these parts to the cab still needs a clean up inside but looks good. The fire box has been made up as has the cabin floor but no paint as yet as there is more to add here.
This page was generated in 0.404 seconds.
