Teds Build Diary Options
Tanna Ted
#1 Posted : 18 March 2014 12:58:14
Here is my build so far
Tanna Ted attached the following image(s):
Ted
______________________________________________________
Current Build: HMS Sovereign of the Sea
#2 Posted : 18 March 2014 13:22:29
Nice start. Looking forward to your progress
NickYates
#3 Posted : 18 March 2014 23:10:39
Great start mate, good to see another Aussie. Cool
Tanna Ted
#4 Posted : 27 March 2014 00:03:15
I have now completed Issues 1, 2, and 3. Looking forward to the next issue.
Ted
jock
#5 Posted : 27 March 2014 00:30:27
Looking good. Be careful to keep keel straight and the frames level
Previous builds
Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour
http://jockspage.webs.com/
Tanna Ted
#6 Posted : 27 March 2014 04:24:23
Hi Jock,
I am checking that aspect all the time. Thanks for looking
Ted
Marcel
#7 Posted : 27 March 2014 12:47:35
Looking great, keep an eye on the flatness of the deck that it does not 'wave'.
Soon the fun part will begin.
Sovereign of the Seas
Tanna Ted
#8 Posted : 27 March 2014 22:37:36
Thanks Marcel for your comments. I am always checking for both level and squareness. Cant wait for the next issues.
Ted
#9 Posted : 27 March 2014 22:59:16
Looking good Ted, nicely done....Cool Cool
#10 Posted : 27 March 2014 23:19:50
Tanna Ted
#11 Posted : 28 March 2014 00:01:59
Thanks Steve, appreciate you looking at the build.
Ted
#12 Posted : 28 March 2014 08:04:52
BigGrin Looking good Ted keep the pics coming rgd MartynBigGrin
Tanna Ted
#13 Posted : 29 March 2014 00:35:44
Thanks Martyn. More pics will be coming as I have just finished Issue 4.
Ted
George1
#14 Posted : 09 April 2014 05:17:38
Looking professional so far Ted.Cool
I made a mistake of using too narrow a base board for the false keel and 90 degree angle for rib frames as per the choice of building so in issue pics. I can see it being a very good thing to have regarding keeping all rib frames at a definite 90 degrees. Not difficult to construct. Apparently positions important when decking comes. So in my case I won't glue in till decking arrives in case of necessary adjustments. I see in Tommick's build he glues in later after decking is on by brushing on glue re joints. So will go that way.
George1
Building HMS SOTS
Tanna Ted
#15 Posted : 09 April 2014 06:08:06
Thanks George for looking at the build so far. I will be doing the same and gluing later.
Next Mag arriving tomorrow BigGrin Been a long two weeks Drool
Ted
bb1949
#16 Posted : 09 April 2014 14:55:50
Hi George. I made an error with the rib frames on another build and in hind sight should have applied the deck as you have suggested and then glued the ribs. I need to do some adjusting which the balsa infills can help resolve. The sovereign build is on track though except this last week has been work work work with little extra time to do anything else.
George1
#17 Posted : 09 April 2014 15:59:52
Hi bb1949.
Re the rib frame gluing later I got that from Tommicks official build. It should make it easier to ensure first deck goes in ok as there is little room for error re the slots in the deck pieces. Just have to make sure when that time comes everything especially mast hole is exact in position. Still a few issues off yet.
Geoege1
Building HMS SOTS
bluedot0
#18 Posted : 10 April 2014 02:05:50
Rank: Amateur level 2
Hi Ted
Looks great so far, keep up the good work...
Regards Phil
You only live once, but if you work it right, once is enough.
Building - Bismarck, Akagi, Warspite, Gato, USS Enterprise (carrier) and D51
Tanna Ted
#19 Posted : 10 April 2014 02:34:47
Hi Phil,
Thanks for looking at the build
Ted
#20 Posted : 10 April 2014 15:46:13
great start, looking good,Cool
This page was generated in 0.174 seconds.
