Thanks Andy and Jase   . Best regards all. Mark
 Hi All This month its the fire box/boiler area and the addition of the straps. Nothing of concern here and quite a fast build it also starts to give a good idea of its size as the drivers cab is still to be added. More soon regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All More bits to add, the steps ,sand box [the shape of the sandbox gave the D 51 its nickname of the slug ]and pipes and finally the lower firebox sides. More soon Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I have a bottle of the same Tamiya thinner (I'm guessing that's what it is?) and it's a pretty big bottle , so looking at the pictures I can see that's a VERY big Kit! Brilliant work as always Andy Spencer
 Hi Spencer Your correct on the thinners bottle I use the empty's as props/holders when I use the airbrush but there useful for other things too. Thanks for looking in and your comments. regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
That paint finish looks nigh on perfect Andy, a normal matt black just does not look scale like sometimes, but the Rail match weathered works a treat......You are setting the standard to aspire to with it..........Tony
 Hi Tony Thanks for looking in and your comments. I agree about the Railmatch colour it gives that oily blue black colour that comes into its own on the larger area's of the loco, as for setting a standard  there are im sure some better renditions out there but thank you for the compliment. regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 14/03/2013 Posts: 43 Points: 129 Location: Calwell ACT AU
Great work Andy....I like the black you've used, I think it's quite appropriate for this kit. I've been toying with the idea of a satin or flat black as I don't have a lot of choice here, it's Humbrol or.....Humbrol.....Phil You only live once, but if you work it right, once is enough.
Building - Bismarck, Akagi, Warspite, Gato, USS Enterprise (carrier) and D51
 Hi Phil Thanks for your comments and looking in most appreciated. Have you tried searching on e-bay for 'railcolour weathered black' you may get some from off there, if not have you considered these from Vallejo http://www.ebay.co.uk/it...amp;hash=item4ad0c3f4a6
and http://www.ebay.co.uk/it...amp;hash=item2eccac5ac4
One or the other could bring the Humbrol to life  hope this is of help regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
She's certainly looking fab Andy and great credit to your painting skills.... Regards Alan
 Hi Alan Thanks for looking in and your comments, there's more to come on the painting front regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, thanks for the links, unsuccessful finding weathered black, but you've given me and idea....watch this space....Phil You only live once, but if you work it right, once is enough.
 Hi Phil Glad I could help regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Today I received the new set of parts which included the backhead and the water level boiler sight's these as I have noticed from pictures are cast in the solid where they should be a frame with an inner tube with 3 panels of glass surrounding it just incase it blew to stop splinters. My intention was to always remove the central solid part and replace with a frame ,inner tube and outer glass. So here are todays results the centre's have been removed and the frames have been made up ready for painting, the glass tube and outer glass panels will be added later. More soon regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
very nicely done andy. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
That looks like a nice job you are making of them Andy, may have to "nick"  your methods when I get to this section................Tony
Great job as always
J“Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Andy, Loving this build, the detail is great. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looking good Andy....lovely work,.. Regards Alan
 Hi Karl Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (5)
