gun ports Options
johny5
#1 Posted : 10 March 2014 20:56:02
Rank: Amateur level 2
when cutting gun ports the two planks have no suports it looks like thay will fall out any on had the same problem
stujue
#2 Posted : 10 March 2014 21:37:49
Hi Johny
As long as you have glued the edges of the planks to each other, you shouldn't have a problem. the area you will need to watch most is the gun port next to the door openings. there is not much between these and need some care. if a plank does come loose then i don't think its too hard to fix it.
Good luck. the key is to take your timeBigGrin BigGrin
Cheers
Stu
Cheers Stu
This page was generated in 0.141 seconds.
