I am building the Caldercraft Victory and have a problem in drilling the small 0.5mm holes required (looks like hundreds of holes will be require so it will be worth getting the right gadget to do a good job). I have a 'cheap' 12volt drill which seems a bit too powerful - in starting to drill the drill bit 'bounces' and does not bite into the wood immediatly Tempted to try a Archimedean Drill Stock http://www.cornwallmodel...uk/acatalog/dr1411.html
Any hints please?? Currently a month into the build and have just started the copper tiles - 'great' fun looking forward to finishing them in a week (or twos??) time Thanks in advance Julian
Hi Julian, An Archimedes pin vice drill is a valuable piece of any builders arsenal of tools and one that will serve you well for this purpose. Spencer
Joined: 10/10/2010 Posts: 690 Points: 2,133 Location: Dorset
Hi Julian You may also like to try the Pin Vice. I found them easier to use/control when drilling numerous holes in my Victory. about the same price as the Archimedes. One thing to note there is an additional chuck "hidden" in the handle. Took me weeks to accidentally discover this when changing drill bits one day. The handle came appart and bingo an additional chuck stored in the handle. GilShapley attached the following image(s): Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
one hint and tip I keep giving,is the drills are expensive and break easily, use dress makers pins,cut of the head and the cut end is the the drilling end,saves a fortune.works with a power drill and pin vices. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Joined: 16/03/2014 Posts: 516 Points: 1,563 Location: Perth Western Australia
Hi karl1113 Thanks. Another great tip that I'll be taking on board. Lot cheaper than drill bits. Regards George1 Building HMS SOTS
karl1113 wrote:one hint and tip I keep giving,is the drills are expensive and break easily, use dress makers pins,cut of the head and the cut end is the the drilling end,saves a fortune.works with a power drill and pin vices. Karl your a genius “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Got the archimedes drill - it works a treat - thanks for the help
Julian
Guest (6)
