Rigging The Corners of The Sails Options
Castos
#1 Posted : 04 March 2014 16:45:20
Hi AllConfused Confused Confused
Please advise as I could have missed the instructions. Must the bottom corners of the Foresail and Mainsail must be attached? Where must they be attached to?
If instructions are in the magazine - which number?
Thanks in advance.
AndreConfused
Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
#2 Posted : 04 March 2014 17:45:10
hi cass, the fore sail and main sail are tethered by bowlines and the corners are not used in the fully rigged sails, the bowline is half way up the side of the sail and is tied off at the mizzen bitt rack, two more lines are tied to the bowline 1/4 way up from the corner and the third line is between those other two.the fore mast is the same with three bowlines which tie of at tha main bitt rack.
Castos
#3 Posted : 05 March 2014 15:19:07
Thanks Karl.
I will follow the steps in the magazine, but was under the impression that I missed something.
Andre
Built: HMS Bounty
#4 Posted : 10 May 2014 09:20:26
Hi Castos, I haven't started this build yet so can't be sure but maybe a look at Bernd's build diary may help you solve the problem,,,, hope this link helps you out....
http://forum.model-space...sts&t=4698&p=12
#5 Posted : 10 May 2014 12:13:30
Neither sail hangs loose at the corners.
The Fore sail, page 11 of issue 105 shows line 'D' attached at the corners and two blocks left free.
The Sprit sail, page 13 of issue 109 shows line 'E' attached at the corners and a block left free.
The Main sail, page 11 of issue 108 shows line 'F' leading to the corners.
Depending on the set up of the sails, not all blocks would be in use at the same time.
#6 Posted : 10 May 2014 12:20:30
hi castos, if you go to my build of vic, about page 25 you can see where I rigged my mainsails.
Castos
#7 Posted : 10 May 2014 13:32:42
Thanks all and to Tomick for pointing out in which magazine the instructions are.
Built: HMS Bounty
pierre50
#8 Posted : 17 June 2014 15:59:02
If I understand you correctly are you talking about the rest of the pulleys on the corners of the sails? Issue 117 page 11?
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
This page was generated in 0.106 seconds.
