Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
Hi Fellow builders I am building a trawler for the first time and would like to build the interior of the cabin area which is not included in the build. The ship is the Artesania Latina Carmen II The model is 1:40 scale but I am not sure what size ships wheel to order. Can anyone please advise? Thanks You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
Hi Rif-Raf, I don't know if this is any use to you? if you end up having to scratch build.
http://www.thenrg.org/re...es/makingshipswheel.pdf
Jase“Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
To get a good size, measure the diameter space of where the wheel is to be fitted and what would look right, as sometimes scale size can look too large/small.
A few to go at here..
http://www.cornwallmodel...amati_ships_wheels.html
http://www.mobilemarinem...talog/Ships_Wheels.html
