Allan Options
Allan
#1 Posted : 14 July 2010 13:00:01
Hi does any one know if there is an exactness to the oar slots in the launch ?
Mike Turpin
#2 Posted : 14 July 2010 13:44:15
Not sure what you mean, can you expand? Are we talking size or position or ...
Mike T
Capt Stedders
#3 Posted : 14 July 2010 14:32:48
Ssshhh... don't mention the oar slots..
Laugh
In answer to your question, if it relates to their positioning, would be a definite 'yes' (I'd follow the mag build..)
If it relates to the exact dimensions of the oar slots themselves, then the answer to that question would be a 'yes' as well - but a fine, flat sided needle-file size 'will do' for all but the most accuracy obsessed.
Schnellboots on back burner
Tools.
Allan
#4 Posted : 14 July 2010 15:18:44
Mike T
It would be the distance between the slots and the distance from the stern to the first slot?
Allan
Mike Turpin
#5 Posted : 14 July 2010 15:26:41
Hi Allan
You can stick to the instructions in the magazine build or check out an actual picture of the launch to get an idea.
I did my oar slots a week or so ago and am now having second thoughts about their width. I just used a needle file as Capt Stedders is suggesting, but I'm not happy with my oars and may widen the slots and adapt the oars somehow.
Mike T
amipal
#6 Posted : 14 July 2010 17:28:42
I followed the mag's instructions, and this is how mine turned out:
I used a flat needle file. Just make sure you don't file down to far - better to come up short than have to fill.
Tiswas
#7 Posted : 14 July 2010 17:36:46
Nice clean launch there Amipal, hope mine turns out 1/2 as good.
TIS
comic123
#8 Posted : 14 July 2010 18:34:47
Good jobBigGrin Gave mine a first coat of white paint last night Drool still not brave enough to post picsBlushing Blushing
CMB
#9 Posted : 14 July 2010 23:44:50
I am still playing with my launch build, and seeing the latest pics have decided to try and emulate the actual painted stripes as shown across the transom.
I modified the oar slots today, they are now 2mm deep by 2mm wide and I think they look OK.
Will post pictures later when I have sorted out how to do.
amipal
#10 Posted : 14 July 2010 23:48:15
Thanks Tiswas and comic123 BigGrin
Spent a stupid amount of time on it so far, will post some pics up on my build diary in the next couple of days I expect.
