Joined: 01/10/2012 Posts: 19 Points: 57 Location: Brighton
So in 33 it says step 7: (9 row up) "Taper a strip betwn 5/6 --> midpoint of 16. THEN 16-21 using SAME STEPS 8-10... Does this mean Taper both sides of the strip? Im confused as the 8th row made rib frame 7 and 13 slightly under the plank.
hi ex, no taper just one side of the next series of planks. try this linkhttp://forum.model-space.co.uk/default.aspx?g=posts&t=4775&p=6 Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Hi Ex, looks ok to me from what I can see on your pic.... If you have a close look at issue 33 of Mr T's official build the pics there will show exactly what you need to do.... The taper starts at the beginning of the plank which sits between ribs 5 & 6 and gradually increases to end of the plank at rib 16... Link to Mr T's build is here.... http://forum.model-space...aspx?g=posts&t=6303
Also from page 20 of my build you will see I have covered the planking of the hull quite extensively..... Hope this helps and look forward to hearing how you get on..... Regards Alan
karl1113 wrote:hi ex, no taper just one side of the next series of planks. try this linkhttp://forum.model-space.co.uk/default.aspx?g=posts&t=4775&p=6 Awesome, done. Im now on step 7 on Issue 34 (the 1st 150mm planks) Do I just glue it on top of the previous? its gunna be tricky because theres no ribs to support the plank. will it not snap off easy??
just continue as mag. instructions, Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
