1/72 Kyushu J7W1 Shinden Build Diary Options
#1 Posted : 15 February 2014 15:28:10
BigGrin Hi All
I recently did a kit revue of this model that I got off e-bay, Here is where the build diary will be.
Firstly the casting sprue's and flash were removed then the parts cleaned up and any air bubbles in the resin castings filled using liquid putty. Lead was added to the nose area in the holes left in the casting and the two sides of the fuselage joined together and shaped to match then the wings and engine casting were joined together with the forward fuselage sections.
At the moment I am slowly building up putty in the joint lines until they are filled then starts the shaping process to make all the parts one.
More soon
#2 Posted : 16 February 2014 18:49:07
BigGrin Hi All
After lots of filing, filling and sanding the 1st light coat of grey undercoat goes on this is more to highlight any blemishes or places missed . Now its a case of rectifying those places so a nice even and smooth finish is obtained.
More soon
#3 Posted : 08 March 2014 20:35:42
BigGrin Hi All
Some more progress, the front stub wings have been fitted and the rear stabilizers with there wheels attached. The undercariage has been prepared and fitted and the first coats of putty added to the joints ready for shaping. More soon
#4 Posted : 08 March 2014 21:08:18
#5 Posted : 08 March 2014 21:28:32
BigGrin Hi Steve
The liquid putty is great it will fill gaps/holes but sometimes needs a couple of applications to build it up, using a brush is possable but it will ruin it I have found runing it in with a cocktail stick works fine.
It must be left for at least 24 hours to fully cure but then it sands quite freely like squadron. Here's a link to where I got it from the Mr Hobby Resin Primer is top notch too.
http://www.emodels.co.uk...ic-kits/-c-159_937.html
#6 Posted : 09 March 2014 09:57:35
I guess the putty is ideal for the fine joints etc and is thinner than the Squadron putty? looks an interesting product.
Build looking great AndyCool
#7 Posted : 09 March 2014 10:04:49
BigGrin Hi Jase
It flows into joints as its a liquid and fills up tiny cracks like you say the only bad thing I can say about squadron is that it sometimes fails on the smaller joints and wont fill them properly. Thanks for looking in and your comments
#8 Posted : 09 March 2014 10:08:26
arpurchase wrote:
BigGrin Hi Jase
Yes I agree Squadron is great for bigger filling jobs, so this putty looks like a good additional filler.
#9 Posted : 09 March 2014 13:26:14
BigGrin Hi All
The excess filler after being left overnight has now been removed from the area's its not needed and the addition of the radio ariel's on the lower fuselarge using plastic rod. Now its time to undercaot and tidy up ant blemeshes that still show.
More soon
#10 Posted : 09 March 2014 20:52:19
BigGrin Hi all
Just a small update the model has been fully undercoated now and cleaned up where needed.
The first coat of Grey-Green has been sprayed onto the under surfaces. once this has had time to fully cure its masking and spraying the top surfaces.
You may have noticed that no decals were included with the kit so I have bought some 1/72 decals off the webb just the meat balls any yellow will need to be sprayed/painted
#11 Posted : 15 March 2014 19:16:15
BigGrin Hi All
Some more progress, the upper surfaces have had a coat of IJN green and then a wash of umber to bring out the panel lines and dirty her up. There is still some painting to do and im still awaiting the arrival of the decals.
#12 Posted : 15 March 2014 19:48:12
Looking good AndyBigGrin
can I ask which method you used for masking the wavy lines, was it cut masking tape or did you use the blu-tack method?
J
Tanasius
#13 Posted : 15 March 2014 19:57:45
Rank: Amateur level 2
Coming along nicely, love the shape of the Shinden, was very tempted with the Zoukei Mura in 1/32.
http://www.zoukeimura.co.jp/en/...ts/sws01_shinden_cl.html
Rob.
Builds, deag Zero, D51, Senna MP4/4
#14 Posted : 15 March 2014 20:04:02
BigGrin Hi Jase
Thanks for looking in and your comments, I used masking tape and a scalpel to get the wavy line, just my preferred method
#15 Posted : 15 March 2014 20:13:21
BigGrin Hi Rob
Thanks for looking in and your comments, I have been using the Maru version as an aid to painting as all you got with the kit was a small page of instructions. I have my eye on the Horten bomber
http://www.zoukeimura.co...ment/oyajiblog_050.html
also if you scroll down to the bottom they are developing the Dornier Arrow heavy fighter
Tanasius
#16 Posted : 16 March 2014 00:24:51
Hi Andy,
Yes both very nice I might be tempted.
Rob.
#17 Posted : 16 March 2014 17:48:58
BigGrin Hi All
the front wheel has been painted and fitted as have the propelor and spinner, the yellow warning bars have been painted on and finaly the canopy added, this was stuck on using glue and glaze.
All im awaiting now is the decals to finish her off
More soon
#18 Posted : 18 March 2014 14:00:19
BigGrin Hi All
My decal's were waiting for me when I got home last nightLOL . They are from a Polish company and are very fine with a minimum of film edging and there are at least 40 different sized decals on the sheet that are all numbered.
In the package there is also a sheet of paper with the Japanese aircraft codes and the sizes to be used on your model a neat and tidy way of doing it too.
Now to add them to the Shinden
more soon
#19 Posted : 18 March 2014 19:22:24
BigGrin Hi All
The decals have now been attached and a final coat of matt varnish to seal everything in.
So here she is not too bad for a 1st effort in resin kits and an old one at that
#20 Posted : 21 March 2014 21:32:17
Love it Andy Drool something soooo satisfying about working with Resin kits. Fantastic stuff mate and well done Cool
Spencer
This page was generated in 0.291 seconds.
