 Rank: Beginner Level 1 Groups: Registered
Joined: 06/06/2013 Posts: 5 Points: -2 Location: Malaysia
I need help on removing the decals on the Vettel's helmet. Because the decal was at the wrong position, and now that its dried its pretty hard to remove it. Any advice?
Hi unitedfan I would suggest you use micro set or micro sol and using a small flat brush getting under the decal. Once you have managed to get under it, start to work the micro sol under the decal Nd you will find it will be easy enough to lift and reposition. Fell free to ask I any more help is required Spencer
Hi Warthog,
Thanks for the tip, may I ask that the brush has to be soft or just any brush will do? And hopefully I can find a micro set at my area.
