drill bits Options
sophie2012
#1 Posted : 07 February 2014 22:05:26
guess the two drill bits provided will burn out and go blunt think mine are heading this way
has anyone a link to buy good quality 0.7 and 1.0 m micro drill bits don't want a set of other sizes
any advice
#2 Posted : 07 February 2014 22:54:30
BigGrin Hi Sophie
I searched flee-bay for both sizes and got both in sets of packs = 10 drills , both for under a £5 with postage below are the ones I used but they may be out of stock now
http://www.ebay.co.uk/it...amp;hash=item565aa52ee4
http://www.ebay.co.uk/it...eName=ADME:L:OU:GB:3160
hope this helps
experten
#3 Posted : 08 February 2014 01:13:21
I am at the tail end of my build, and both my bits are in good shape. I didn't use a motor tool to spin 'em though, just an old fashioned pin vise. (hand cramps while drilling the zinc!) If you are using a Dremel or some such, slow it waaaay down, and you should be ok. There isn't anything hard in the later stages, just aluminium and white metal.
Tired, Old, and Cranky!
#4 Posted : 08 February 2014 09:50:23
BigGrin The hardest metal parts to drill I have found are the spark plugs the rest of the parts are quite soft in comparisonCool
This page was generated in 0.155 seconds.
