 Hi All The hull has now been sanded back ready for the second layer of planking regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good,coming along very nicely. Are there no planks to bend around the bow on this one, or are filling blocks used there? Steve
 Hi Steve Thanks for looking in and your comments. The bow has light ply fillers that are sanded to profile with the planks then the final planking go's onto this regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi Steve Thanks for looking in and your comments. The bow has light ply fillers that are sanded to profile with the planks then the final planking go's onto this regards Andy That saved an awful lot of work on the 1st planking then, nice work anyway. Steve
Cracking smooth finish on the first layer Andy, you usual high standards I see....  .. Well done.... Regards Alan
 Hi steve Its the first time iv used this method on a bow area and will report on its merits when I get to that stage in the build, Again thanks for looking in regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Alan Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Now the major planking is finished I can start adding the deck furniture namely 2 doors and seven sets of steps. The cannon are not fixed they were just used to aid the positioning of the steps . regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Made a start on the launch and the planking regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Some more progress on the launch regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Pro  Groups: Registered
Joined: 19/09/2012 Posts: 101 Points: 245 Location: Wirral
Im guessing that all of these style deag ships go together the same then? (Still waiting to start my vic, but in the process of moving house so dont want to get started then risk damaging it in transit) Completed: Earth, Moon, Sun Orbiter Build a Model Solar System
Under Constuction: HMB Endeavour HMS Victory Mitsubishi Zero Tiger Tank D51
 Hi Rover You could say that but each ship has its own characteristics that eventually make it a different build some like the Victory are single planked whilst the Triny is double planked each having its own challenges and quirks so although they look alike they each have differences. Hope this helps regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All I have now concluded pack nine with the fitting of the Thwarts still more to add on the launch as yet and I should receive these parts next month regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Launch looks great Andy “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Jase Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy. Looking realy superp. Look forward to seeing your progress Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Hi Ian Thanks for looking in and your comments, I also noticed from the pics I had a dark stain around one of the hatches this has now been rectified aswell regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Not much to do this month as the instructions are still finishing off the 1st layer of planking. The launch is now finished and has a couple of coats of matt varnish but im not too happy with the finish on this so will probably recoat in satin. That just left a grating to make up apart from the anchor's but they will be made up when there needed. Next month [pack 11] has more bits for the x section so will carry on with that in the spate build diary regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All I wasnt happy with the matt finish on the launch so here she is after a couple of coats of gloss Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
The launch looks great with the gloss Andy Cheers Steve
