micro screws Options
sophie2012
#1 Posted : 26 January 2014 17:20:31
whats the best screwdriver out there for these very very small micro screws in the kit
#2 Posted : 26 January 2014 17:28:40
BigGrin Hi Sophie
The screwdriver provided should be more than adequate for the job
sophie2012
#3 Posted : 26 January 2014 17:32:50
i can't find what i did weeks ago with the screwdriver that came with the kit
if i want to buy a replacement what size head/bit should i get
#4 Posted : 26 January 2014 17:40:22
BigGrin Any of the below should sort you out
http://www.amazon.co.uk/...;ref=pd_sl_3qgf37k8ib_b
experten
#5 Posted : 27 January 2014 07:10:49
One note;
The second thing I did after driving the very first screw was to magnetize the screwdriver. This saved me an endless amount of heart-ache, I am sure!
Tired, Old, and Cranky!
Silent_Running
#6 Posted : 27 January 2014 09:33:51
experten wrote:
One note;
Top tip there Mark. Magnetising the screwdriver does make it lots easier to control screws when trying to place them. They always seem to fall down a small gap and then you are struggling to get them out.
BigGrin
Percyiris
#7 Posted : 22 April 2014 02:40:00
I haven't lost one of the micro screws yet, but (unless I've missed the spec for them) where would one source them? They are metric I assume. Then again for a self tapping screw that small, it probably doesn't much matter.
Thanks in advance from a slowly warming southern Ontario. I wonder if I'm the only Canadian fortunate (and foolhardy for indulging myself) building this great model?
#8 Posted : 22 April 2014 20:33:44
BigGrin Hi Percyiris
With any luck you will end up with several spare screws as you progress which will come in handy later. Hope this helps
