micro screws Options
sophie2012
#1 Posted : 26 January 2014 17:20:31
whats the best screwdriver out there for these very very small micro screws in the kit
#2 Posted : 26 January 2014 17:28:40
BigGrin Hi Sophie
The screwdriver provided should be more than adequate for the job
sophie2012
#3 Posted : 26 January 2014 17:32:50
i can't find what i did weeks ago with the screwdriver that came with the kit
if i want to buy a replacement what size head/bit should i get
#4 Posted : 26 January 2014 17:40:22
BigGrin Any of the below should sort you out
http://www.amazon.co.uk/...;ref=pd_sl_3qgf37k8ib_b
experten
#5 Posted : 27 January 2014 07:10:49
One note;
The second thing I did after driving the very first screw was to magnetize the screwdriver. This saved me an endless amount of heart-ache, I am sure!
Tired, Old, and Cranky!
Silent_Running
#6 Posted : 27 January 2014 09:33:51
experten wrote:
One note;
Top tip there Mark. Magnetising the screwdriver does make it lots easier to control screws when trying to place them. They always seem to fall down a small gap and then you are struggling to get them out.
BigGrin
Percyiris
#7 Posted : 22 April 2014 02:40:00
I haven't lost one of the micro screws yet, but (unless I've missed the spec for them) where would one source them? They are metric I assume. Then again for a self tapping screw that small, it probably doesn't much matter.
Thanks in advance from a slowly warming southern Ontario. I wonder if I'm the only Canadian fortunate (and foolhardy for indulging myself) building this great model?
#8 Posted : 22 April 2014 20:33:44
BigGrin Hi Percyiris
With any luck you will end up with several spare screws as you progress which will come in handy later. Hope this helps
This page was generated in 0.101 seconds.
