Formula364 Options
Formula364
#1 Posted : 22 January 2014 22:39:49
Rank: Newbie
Hello,
I'm looking for a complete functioning suspension model.
Production car frame rail with springs, dampers, sway bars, tires.
I'm looking for a working model to teach suspension and driving techniques with. Does anyone know of such a thing?
Thanks,
Brian
experten
#2 Posted : 23 January 2014 15:39:25
I think the problem you might run into is that any model is going to differ from the 1:1 item, simply due to the limitations of scale. Of the Models that DeAgostini has on offer, the closest to what you are looking for might be the Hummer RC car. Even that though has an RC type suspension.
If something does come to mind, I'll post it here!
Tired, Old, and Cranky!
experten
#3 Posted : 23 January 2014 16:01:53
OK. I did find this;
Not really being a "car guy" beyond appreciating the aesthetics, I really don't know what I am looking at, but there IS a hell of a lof of suspension detail in this kit, and Pochers are second to none when it comes to detail. The write-up on the parent website does say that the suspension and steering are functioning.
http://www.scaleautowork...er%20Lambo%20Manual.pdf
HTH!
Formula364
#4 Posted : 23 January 2014 18:46:01
Rank: Newbie
Thanks Experten,
I'm checking it out now.
I'm hoping to find something that driver's ed instructors, track instructors, body shop & alignment shops could use to teach/show customers the concepts of brake dive, acceleration squat, and weight transfer through cornering, and gear heads in general.
Something like this with a larger/non-scale steering wheel, and the spring rates would have to be exaggerated for visual impact.
Frame Suspension
Formula364 attached the following image(s):
experten
#5 Posted : 24 January 2014 18:04:08
oh. Wow. Ummmmm.....
what comes to mind are the old Monogram 1/16 Trans Am or AC Cobra kits. I really can't think of anything that is truly operational in the way you seek. you might try a google search for 1/4 scale cars. There are guys out there that build in that insane scale.
Formula364
#6 Posted : 24 January 2014 18:19:02
Rank: Newbie
That was an example of the visible frame & suspension - not an example of scale. Still looking for desktop scale and maybe die cast.
If it's not out there, who could I pitch it to for manufacture? It's a niche market, but cars will endure.
Thank you, gentlemen.
