assembling the springs Options
mikey
#1 Posted : 19 January 2014 16:47:58
Just been having a look at the build logs and noticed that everyone when assembling the springs has placed the nut on top of the spring were as i have built mine with the nut on the bottom, Looking back at the instruction it i who has got it wrong so my question is do i need to turn them all round or would it not matter if left as they are.
Regards Mike
[img][/img]
Current Build`s
Sovereign of the sea`s
HMS Victory x section
D51 Locomotive
Spitfire
Harley Davidson Fat Boy
Mantua titanic
#2 Posted : 19 January 2014 17:12:04
No I don't think make any difference. The reason why the nuts are on top is simply because it is easer to assemble that way.
J
mikey
#3 Posted : 19 January 2014 17:34:54
Thanks Jase, trust me to do it the hard way Crying
Regards Mike
Current Build`s
D51 Locomotive
Spitfire
Mantua titanic
#4 Posted : 19 January 2014 18:22:08
Should a nut work loose when it is being run, you wont be able to tighten from the top with a screwdriver as the boiler will hinder this. But with the nuts on the top you should be able to access the nuts from the side with a spanner.
mikey
#5 Posted : 19 January 2014 20:36:07
Thanks Mr T that's a good point i will turn them around.
Regards Mike
Current Build`s
D51 Locomotive
Spitfire
Mantua titanic
#6 Posted : 20 January 2014 00:04:21
BigGrin Hi Mikey
The use of some thread lock may also be a good idea
mikey
#7 Posted : 20 January 2014 21:29:03
Hi Andy, The screws are all now in the right way and thread locked, It is now ready for its final coat of black paint, Looked in on your build log and its looking very good, I hope my paintwork looks as good as yours.
Regards Mike
Current Build`s
D51 Locomotive
Spitfire
Mantua titanic
#8 Posted : 20 January 2014 21:41:00
BigGrin Hi Mikey
Im sure your paint work will be more than good enough the thing is with the weathered black it gives shades of oily dirtiness that builds up as its applied. Best of luck with your build
AndyBigGrin
This page was generated in 0.101 seconds.
