secondary planking Options
neon
#1 Posted : 15 January 2014 12:42:59
Just about to start the upper secondary planking. If anyone could give me some advice on the following I would appreciate it. What type of glue ? Is super glue ok? Is there a taper on the first strip or do you just bend it along your reference line ? I would love to use a caulking effect. It has been suggested that a black marker can be used. I have found it hard to draw a black line on this type of timber. Any help would be appreciated.
#2 Posted : 15 January 2014 13:40:29
Hi Neon,BigGrin
This is how mine worked out.
I used quick grab/rapid cure Aliphatic glue, it gives you time to make adjustments, superglue will set far to quickly!!
The first row of planking followed the reference line nicely until it reached the bow, where I let it do it`s own thing and rise above the line.
The gap left at the bow can be sorted with a small infil and won`t show when all the bow work is done.
The caulking I done with a permanent black marker, firstly ran a fine sandpaper along the edge, this stops ink bleeding to far into the plank.
The marker was bought from Staples and has a large wedge end, so just ran along each edge of the plank and it worked fine.
Hope this helps,
neon
#3 Posted : 15 January 2014 14:01:34
Cheers Delboy. I can see what you mean about the super glue. No time for adjustments. Got a marker so that seems to be working out for me. Will get stuck in now.
#4 Posted : 15 January 2014 16:02:25
Hi Neon,BigGrin
Glad to help, just don`t go to fast at second planking as it`s thin and will show any errors.
As has been said on this forum on many occasions, "this is not a race".
Take your time and I`m sure you`ll be happy with the results. Cool
This page was generated in 0.095 seconds.
