12 Pages «<9101112>
Kobus' SOTS Build - SA Options
#201 Posted : 14 January 2014 19:35:23
Hi Kobus, as I thought it would, looks as if it has sanded down very nicely indeed..... Keep the pics coming....Cool Cool
KobusBeukes
#202 Posted : 14 January 2014 19:43:44
Hi Alan
Thanks for the nice feedback! LOL
Started with the port side, sanded it down and filled with wood filler. Will sand down tomorrow and hopes it comes out the same as the starboard side!
Kobus
Current Build
HMS Sovereign of the Seas - First Build
Marcel
#203 Posted : 24 January 2014 06:50:09
Cool
Your build encourage me to continue. I am still on the bottom side of the hull, planning the cannon ports. This is an intrigue part of the build which can ruin my build. I have still a lot of years in my body left, therefor I have ample time to finish it.
Overall your build looks fantastic. Lots of TLC displayed here
Marcel
KobusBeukes
#204 Posted : 25 January 2014 20:43:34
Marcel wrote:
Cool
Marcel
Hi Marcel
Thanks for looking in and the nice comments. I'm currently busy cutting and FILING the gunports! You must be so careful with the measurements, I started on the port side and marked and cut the first gunport just to realise that my measurements are WRONG Cursing ! Luckely I used a sawblade in the Dremmel and was able to glue the piece back in place! Moved over to the starboard side and made double sure everything is correct. The first line is now completed, jusy the filing to the correct size.
Kobus
Current Build
KobusBeukes
#205 Posted : 07 February 2014 18:17:14
Hi all
A small update.
Completed the gunports on the starboard side. Decided to follow Dominic's lead and fit the gunports before I start with the second layer of planking. I laminated strips of basswood together to get planks of 12 and 13 mm. Then I cut the long edges to 45' and then glued them all together to obtain a box for the gunports. Once dried I cut it in 5 mm strips and dry fitted each one into a gunport. This is the result:
I'm planning to glue it in place, do the final sanding and once both sides are finnished will paint it red.
Kobus
Current Build
#206 Posted : 07 February 2014 18:26:23
BigGrin Very nice work Kobus looking good BigGrin Rgd Martyn
KobusBeukes
#207 Posted : 07 February 2014 19:54:44
Hi Martyn
Thanks for looking in and for the encouragement, much appreciated. BigGrin
Kobus
Current Build
Marcel
#208 Posted : 07 February 2014 21:44:55
You are making good progress, Kobus. I approve of the idea of doing the gun ports now. The veneer is very thin and leave little room for errors.
Remember to drill a small centre marker for the dummy guns while you busy making the ports. You can refer to the Victory build for more ideas on this.
You must be relieved that the first layer of planking is done. Mine has become a daunting job.
Marcel
#209 Posted : 07 February 2014 22:41:03
Coming along very nicely Kobus, lovely job on the port lining....Cool Cool Keep posting those pics.....
KobusBeukes
#210 Posted : 08 February 2014 06:43:44
Thanks Marcel and Alan for looking in and the nice comments! Love
I'm not going to use the supplied 0.6 mm veneer, I'll be cutting my own 1 mm sapele for the top and 1 mm maple for the bottom.
Will have a look at the Victory builds for the dummy guns.
Kobus
Current Build
NMBROOK
#211 Posted : 11 February 2014 00:01:58
Looking great KobusCool If you want absolute authenticity with the ports the top and bottom cill should be parallel to the waterline athwartships.I have developed a new manufacturing technique for gunport surrounds like this on the MF70 enabling perfect squareness and consistancy within 5/100 of a mm.I haven't posted anything anywhere yet but will do fairly soon.
Kind Regards Nigel
KobusBeukes
#212 Posted : 11 February 2014 07:21:17
Kind Regards Nigel
Hi Nigel
Great to hear from you again. Thanks for looking in.
Still need to make 10 gunport linnigs for the port side and will definately keep the MF 70 in mind. Must say the FET table saw worked well cutting the 45° angles.
Kobus
Current Build
KobusBeukes
#213 Posted : 01 April 2014 18:12:44
Good day all
I'm back to my build after a month! Was on holiday in the Western Cape and now I'm sitting at home due to the Platinum Mine Strike in South Africa!
Will use the time to catch up on my build! I'm behind a number of issues as I decided to cut my own planks, sapele for the top and maple for the bottom!
Finished with the starboard side sapele, now busy with the port side. Below is the results.
Kobus
Current Build
#214 Posted : 01 April 2014 19:37:17
Second planking looks good Cool
KobusBeukes
#215 Posted : 01 April 2014 19:45:32
Hi Jase
Thanks for looking in and the nice comment.
The completed side was sanded down to a smooth finish. I'm considering using a white wood filler on the sampele for the treenailing and a darker one for the maple.
Kobus
Current Build
#216 Posted : 01 April 2014 20:05:22
BigGrin Nice to see you back Kobus BigGrin The planking is looking good BigGrin Rgd Martyn
KobusBeukes
#217 Posted : 01 April 2014 21:07:07
Hi Martyn
Good to be back.BigGrin
Thanks for the nice comment. Got ample time on my hands, so should be catching up soon.
Kobus
Current Build
#218 Posted : 01 April 2014 21:56:02
#219 Posted : 01 April 2014 22:27:40
Hi Kobus, so nice to see you are back with us and posting your progress..... Lovely work especially as you have cut your own sapele strips..... Cool Cool .. Keep the pics coming....
KobusBeukes
#220 Posted : 02 April 2014 17:26:51
stevie_o wrote:
Looking fab Kobus and nice to see you back on the SOTSBigGrin
Hi Steve
Thanks for looking in and the nice comments!BigGrin
Kobus
Current Build
12 Pages «<9101112>
This page was generated in 0.312 seconds.
