issue34 Options
val ellams
#1 Posted : 09 January 2014 17:15:36
Rank: Beginner Level 3
hi,coming to the end of the planking,but i can only fit 1 50mm length strip at the end of the hull step 15/16 will this matter later on in the build ,would appreciate some advice thanks valBigGrin
#2 Posted : 09 January 2014 18:47:35
Hi Val, BigGrin
It`s my opinion that as long as you have the ribs covered and none of the tops uncovered you should not have any issues.
Most probably occured if you have had a few wider planks than normal.
My second plank was only needed for a very small part to cover the rib tops.
Hope this helps.
val ellams
#3 Posted : 09 January 2014 19:47:44
thanks for your reply very helpful,all ribs are covered ,your probably right about the thickness of the planks,have a great 2014,Cool val
RobT
#4 Posted : 09 January 2014 21:56:22
Yeah, seconding what Del Boy said. I only had room for about a plank and half at that stage. As long as it covers the ribs and is level with the stern gallery, you are good to go.
#5 Posted : 09 January 2014 22:41:55
Hi Val, agree with Derek. Just make sure your planking goes above the ribs, later in the build you will be cutting them back anyways but you need to ensure you have enough height on the bullworks first..... Cool Cool
val ellams
#6 Posted : 09 January 2014 22:49:22
BigGrin thanks all for your advice ,just waiting for a dry day to start the sanding ,hope you all have a great 2014. val
This page was generated in 0.092 seconds.
