13 Pages «<10111213>
Delboy271155 Sots Options
#221 Posted : 22 December 2013 14:20:12
ian smith wrote:
Hi Derek.
Very nice clean build. Look forward to seeing more.
Cool Cool BigGrin Ian
Hi Ian, BigGrin
Thanks for taking a look and the kind comments.
I`m spraying up the strip wood for lining the gun ports at the moment, then progress will slow for a bit while I actually line the ports.
Before that though, a very light rub down on the white hull and a final coat to apply.
#222 Posted : 05 January 2014 16:20:57
Hi All, BigGrin
This is just a one picture update, as a gun port is a gun port etc.
I have lined some ports and "Yes" a bit of paint touch-up may be required but will do that as a one off job when they are all done.
Next update may be a while as it will be when all gun ports are lined.Crying
Happy Building Cool
#223 Posted : 05 January 2014 17:53:02
Really neat work on those gun port linings Derek, looking great..... Drool Drool
der Gohfelder
#224 Posted : 05 January 2014 17:59:26
Hi Derek!
Very nice, I like it! ThumpUp
Regards, Bernd
#225 Posted : 05 January 2014 21:03:50
BigGrin Nice work Del lots of cutting and fiddling but worth it in the end BigGrin Happy building rgd Martyn
#226 Posted : 06 January 2014 17:07:25
Hi Alan,BigGrin
Thanks for the nice comments.
I think I may have found a task more frustrating than planking.
LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL
#227 Posted : 06 January 2014 17:09:15
der Gohfelder wrote:
Hi Derek!
Regards, Bernd
Hi Bernd,BigGrin
Thanks for looking in and the kind comments.
Bit of a long job, but getting there. LOL
#228 Posted : 06 January 2014 17:11:55
Hi Martyn,BigGrin
Thanks for taking the time to look in and the kind comments.
Only problem I can see is the possibility of a visit to A+E to get the Sovereign removed from my fingers.
LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL
claret
#229 Posted : 09 January 2014 08:59:12
Hi Derek,
looking really nice.
Keep up the good work.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#230 Posted : 12 January 2014 16:47:08
claret wrote:
Hi Derek,
Claret
Hi Claret, BigGrin
Thanks for taking the time to look in and the kind comments. Cool
#231 Posted : 14 February 2014 17:15:12
Hi All, BigGrin
Having literally straightened out my Spitfire build, I`ve come back to the Sots.
This is a small update, but a lot of work has been done.
(most of it repetitive) ie: gun port lining Crying
As for the gunwales, I asked for some advise on the best way to hold them in place while the adhesive set.
I would like to thank those who offered their ideas to this issue and especially Alan (Gandale), whose method I finally used.
The method used is the drill and map pin method, which gave an unexpected bonus of tree nailing if you look close, even though the gunwales have been painted black after filling the holes made.
Below are the results so far Blink
What next ?
Finish the lower gunwale
Line seven more gun ports
Then, I can turn it over and do the other side.
Crying LOL Crying LOL Crying LOL Crying
Happy building
#232 Posted : 14 February 2014 17:50:32
Hi dell,
Must say she's looking good, I like the choice of colour well done m8.
Trev.
#233 Posted : 14 February 2014 18:06:27
#234 Posted : 14 February 2014 20:58:26
tf64 wrote:
Hi dell,
Trev.
Hi Trev,BigGrin
Thanks for taking a look.Cool
As for the colour scheme I`m using the official Sots set and I must say I`m very impressed with results for consistency.
#235 Posted : 14 February 2014 21:04:50
stevie_o wrote:
Hi Del,
This is looking good, will continue to watch this one.BigGrin
Hi Steve, BigGrin
Thanks for the positive comments.
Some of the repetitive sessions do get to me at times, but that`s why I change tack to another build every so often. I also think it helps to put you back on track and pays dividends in the end results when you return to the previous build.
Thanks for looking in and happy building Cool
Marcel
#236 Posted : 14 February 2014 22:26:05
It did came out great. The paint job and veneer does not seems to be damaged. I'll check in again to watch how you had progressed.
Sovereign of the Seas
#237 Posted : 14 February 2014 23:10:15
Fab work Derek and I'm pleased my method worked out for you..... I had the same effect where after filling the holes I was left with what looked like treenailing..... She's looking great so keep up the good work..... will be following.... Cool Cool
#238 Posted : 15 February 2014 20:04:44
Hi Marcel, BigGrin
Thanks for looking in, there are a few very small bits that will need touching in with a spot of paint(mainly inside the gun port linings) but nothing major thankfully.
Happy Building
#239 Posted : 15 February 2014 20:08:22
BigGrin Nice work Del looking brilBigGrin rgd Martyn
#240 Posted : 15 February 2014 20:11:53
Hi Alan, BigGrin
Thanks for looking in. Cool
Not sure which is the more trying task, planking or lining the gun ports.
That said, still not in a rush even though I`m really looking forward to getting into some main building sections for a bit of a change, cos you see a big difference in a short period of time.
Hey Ho just have to wait a while longer LOL LOL LOL
This page was generated in 0.273 seconds.
