Joined: 27/06/2011 Posts: 434 Points: 1,309 Location: milton keynes
Looking Fantastic Andy regards Dan Built - MP4/23, Zero, Deagostini Falcon, Model Airways 1903 Wright Flyer, Senna Mp4/4. Working - Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4 on the bench, Model Airways Sopwith Camel.
 Hi Dan Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 17/06/2013 Posts: 169 Points: 510 Location: Hereford United Kingdom
Looking good squire, I agree with you on the chain mail, I found a lot of loose links, soon put right. putting mail to sleeve is a bit fiddly, just need to persevere.. Bob.
 Hi Bob Thanks for looking in and your comments I also had some chipping of paint but soon fixed Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All All the Tassets are now fitted to the Chest plates still needs a good polish and so its onwards with the sleeves regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, the more I see of this the more I love it...  .. Think you are producing something special here.... Can't wait to see it with the chainmail attached... Regards Alan
 Thanks Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The chain plates have now been sewn onto the silk arm backing starting with the shoulder plate then the hand guards I made a change here with the sewing of the plates as I went round as instructed but then followed it back round so both sides were fixed in place thus a stronger bind. Then all was left was the sewing on of the chain mail to the silk following the set patern, again I changed the way the instructions advised and used long dress makers pins instead of masking tape, this concludes issue 8 regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Lovely work Andy.... Regards Alan
 Hi Alan thanks for your comments Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Coming along very nicely Andy, are you going to source or make a weapon as well? Steve
 Hi Steve Thanks for looking in and your comments. As for the swords probably not I feel with or without then it wont detract from the overall finish as its a lot larger and imposing as it stands. regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Continuing to finish off the left sleeve firstly by adding the retaining straps to the outer wrist area and then adding the toggles and ties. The backing was then trimmed to the correct shape and the yellow swead trim attached to it except for the shoulder are as more attachments are to be made here.Still more to be added here so more soon regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Couple of pics on progress, the swead hand area has now been added regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The left arm is now finished and mounted as is the 4layers of thigh armour. more soon Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Coming together nicely Andy.... Regards Alan
 Hi Alan Thanks for looking in Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All I have made up the second chainmail and plates for the right arm, now to start on the leg guard plates more soon Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 13/02/2011 Posts: 2,239 Points: 6,837 Location: East Sussex
Hi Andy, Just a fantastic job your doing on this armour, I tell you this kit is so close to the real thing, I was at the V/A museum London this week and I had a very close look at Samurai-Armour your work is so close Andy you must be very proud of your work keep sending. Regards. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Hi Trev Thank you for you kind words  . Its a different form of modelling and the lacing can be a right pain but at the same time quite theraputic .One of the reasons I took this on was its closeness to the real thing and your comments have proved my theory correct. Again thank you for your comments, there,s still more to come like the greaves yet regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (5)
