Hi Claret I am well thanks,unfortunately too busy at the moment to work on my SOTS. Kind Regards Nigel
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi, Have progressed a bit more and finished the rear including the lantern. Needed a little filing here and there, but otherwise everything fitted together okay.   Thanks for looking in. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi Claret! A very nice work, well done! Regards, Bernd
 Hi Claret That's a great finish on her rear end  regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
First class Claret, she really is taking on a beautiful appearance.....  .. Very well done..... Regards Alan
Now that the first part of the festivities are over means I could get back to some serious stuff like moving on with the build.... Started work on Part 68 the fitting of the upper quarterdeck.... First took the side panels and these needed a very slight bend in them which was done gently using steam from the kettle. Lined the inner walls in the same manner as I have done all the inner bullworks.. When dry, set about fitting them to the upper quarterdeck area. Dry fitted the upper quarterdeck which needed very minimal adjustment. From there marked out the deck ready for the planking stage. Have cut a number of planks ready for the task and they have already had 2 coats of light oak stain...  .. Tomorrow will get onto painting the outer sides black, planking the deck and finally fitting....  .. Hopefully will update tomorrow again.... Happy building all.. Regards Alan Gandale attached the following image(s):
Hi Bernd. Andy & Alan, Thanks for looking in and posting the nice comments. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
 Lovely neat work Claret  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Dominic & Martyn, Thanks for looking in and the kind comments. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi All, Started work on the side galleries. surprisingly, everything fitted okay with only a little bit of fettling required.   More to follow. thanks for looking in. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Looking really good Claret, you are now at the stage where the build really does start to take on its personality....  .. Very well done... Regards Alan
Hi Claret, Looking really good matey, WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Tidy work, looking great “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Alan, Derek & jase, Thanks for looking in and commenting. Starting to look more 'shippy' with all the bling! Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi All, Finally finished all the gold work on the rear gallery. just a little touching up with the gold paint once stuck on.   Also built up the bell housing. seems alot of housing for such a small bell!!  Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Superb work Claret, looks stunning....  . Regards Alan
Hi Alan, thanks for those comments. Regards Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi All, I have now fitted the figures at the bow. quite a fiddly process.  Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi All, I have now added the oars, bucket and roped anchor to the 'launch'. I used wood glue to glue the coils together and super glue to secure it to the launch deck.   Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi Claret, The detail and lines are looking good matey. Keep up the good work. I think I`m gonna have my work cut out when it comes to gilding those fiddly figurines at the bow. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
