Revell 1/24 scale Trabant 601 build - "The worlds first rusty Trabbi" Options
#1 Posted : 24 December 2013 13:23:22
Hello everyone, I have reached a stage on hms victory where I need to build a shelf before I can proceed so putting that job off I thought Id build something from the stash.
This is Revell's 1/24 scale Trabant 601 - it's a car you either love or hate, I personally like them but then again I used to own a 1968 beetleBigGrin
The kit itself is short on parts as there is no engine to build on this one, there is a later version of this kit with an engine.
So, this is not so much a build diary but more of a testing ground for some new rusting techniques that I have thought up while messing about with my daughters chemistry set - using Iron filings.
So to start with the obligatory box shot - btw, this is a 1990 mold and as I said there is a later kit which is much, much better in every way - Its the one with the white Trabbi on the box. The parts my early kit were very badly flashed and poor fitting as well.
#2 Posted : 24 December 2013 13:31:25
As I said, this is going to be weathered with bad rusting and placed in a simple scene on a street, parked up in a bay - im going to turn it into a ratty looking east german taxi circa 1989,so just before unification as Im going to use the "DDR" plates.
First job was to wash and prime the 1 piece body,but before priming I set to work on it with a dremmel BigGrin This provides nice rough areas for the rust to be placed later. Just to point out I did some of these stages a couple of days ago so I will be updating a lot today!
#3 Posted : 24 December 2013 13:32:14
Nice one looking forward to your experiments
Foz
#4 Posted : 24 December 2013 13:41:56
Very nice Steve. Looking forward to your rusting and seeing the progress.
Foz ThumpUp ThumpUp
#5 Posted : 24 December 2013 13:45:13
Thanks Jase and FozBigGrin , hope you like the end result - like I said I have progressed much further than what I have shown so far, just getting my photos in some sort of order to put on here.
I wanted my Trabbi to be white, if you are doing a rust experiment then you need to see the rustBigGrin so any light colour car will look good.
Next was building the wheels (no vinyl tyres in this kit) and getting all the white parts sprayed. I deliberatly wanted a non perfect base coat of paint so I used a satin white but sprayed it with a cold can in an even colder garage - this gave a slight orange peel effect and the roughness with take the grime washes and rust better.
#6 Posted : 24 December 2013 13:48:20
I posted the last entry without pics so here they are - btw - I masked the one panel at the front as I want this to look like a new replacementBigGrin
The glass in the last pic was horrible to fit, completely the wrong shape so I will tidy this up later
der Gohfelder
#7 Posted : 24 December 2013 14:09:59
Hi!
A very nice model, I like it!!
Only one small mistake: the body of the Trabant was made of Duroplast, so there can´t be rust BigGrin
Regards, Bernd
#8 Posted : 24 December 2013 14:17:56
der Gohfelder wrote:
Hi!
Regards, Bernd
LOL I know this Bernd - and believe it or not I was going to add at the end of the build that I have used "artistic licence" and can anyone spot the mistake, nevermind - the secret is out nowBigGrin Yes, all outer body parts were recycled with waste from Russia I believe, the inner frame was steel though. The duroplast was so tough that they had to invent a bacteria to break it down otherwise there was no way to dispose of it, thats what I heard anyway.
der Gohfelder
#9 Posted : 24 December 2013 14:23:30
BigGrin That´s why the Trabant is called "Rennpappe" in Germany. Free translated: "racing cardbord"BigGrin
Regards, Bernd
#10 Posted : 24 December 2013 14:30:09
Regards, Bernd
BigGrin I like that Bernd, so yes, please try to pretend you don't know this car would not have outer rust. Im using this kit as its the quickest build I have, I do have a Tamiya 1966 beetle that I want to rust up but this kit is the practice piece. I might have known it would be you to spot this before I mentioned it thoughLOL
I have changed the thread title just for youBigGrin
#11 Posted : 24 December 2013 17:13:58
Got my pics in the right order now, I'm currently working on the display base and a figure to go with it and will update later, the car is nearly complete, just some more little details to add and another dirt wash over the rust - told you this was a quickie - only taken 3 days to the stage shown below as I used overnight time to cure the iron filings.
The inside was very simple, just seats and dashboard - I lost the steering wheel and had to make one from wire, you can just see the join in one pic, I also broke the roof rack but made that with wire tooBigGrin The fine parts were very brittle maybe due to age of this actual kit (24 years).
#12 Posted : 24 December 2013 17:20:29
Here is the 1st wash layer using vallejo model color black. The wheel rust is not yet complete either, this is the result of iron filings and pva glue left overnight,it is obviously real rust but is dark as this is the oldest base layer of rust. If I re-wetted it and left overnight again it would turn more orangey but I will do this laterBigGrin
#13 Posted : 24 December 2013 18:05:23
Hi Steve, BigGrin
Firstly I thought looks good. BigGrin
Then thought, heck pop down to Halfords, get some Rust-cure and problem solved.
LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL
You could also leave a wing or a door panel with the red primer to show the owner was at least trying to save it. Blink Blink
Nah, love it.
Some very good distressing work coming on there.
WTG mate, the rusty wheel looks the part too.
Nice one.
#14 Posted : 24 December 2013 21:47:34
Thank you Del.....I thinkLOL
Here are some pics of the iron filings after a night, same as the wheels. As you can see the rust is very dark at this stage but this will be sorted out later with a couple of dabs of ak interactive rust followed by a last touch of tamiya clear orange... more coming up soonBigGrin
#15 Posted : 25 December 2013 22:54:35
Here are some more pics of rust, I have progressed further than this now and the base is also complete but not taken the pics yet.
The rust is now more orange but the original iron filings are still visible as the darker areas simulating the older rust.
Try getting them wheelnuts offLOL
der Gohfelder
#16 Posted : 25 December 2013 23:11:41
Hi Stevie!
Absolut fantasic and realistic, you make a great job!
Looking these pics let me think about my first car..........BigGrin
Regards, Bernd
#17 Posted : 26 December 2013 14:23:48
Hi Stevie!
Regards, Bernd
Thankyou Bernd - The model is now complete with base and is moved to the finished build gallery here - http://forum.model-space.co.uk/...&m=103187#post103187
Thanks for looking BigGrin
This page was generated in 0.519 seconds.
