ian smith wrote:Hi Derek. Very nice clean build. Look forward to seeing more.  Ian Hi Ian, Thanks for taking a look and the kind comments. I`m spraying up the strip wood for lining the gun ports at the moment, then progress will slow for a bit while I actually line the ports. Before that though, a very light rub down on the white hull and a final coat to apply. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, This is just a one picture update, as a gun port is a gun port etc. I have lined some ports and "Yes" a bit of paint touch-up may be required but will do that as a one off job when they are all done. Next update may be a while as it will be when all gun ports are lined. Happy Building Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Really neat work on those gun port linings Derek, looking great..... Regards Alan
 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi Derek! Very nice, I like it! Regards, Bernd
 Nice work Del lots of cutting and fiddling but worth it in the end  Happy building rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Gandale wrote:Really neat work on those gun port linings Derek, looking great..... Regards Alan Hi Alan, Thanks for the nice comments. I think I may have found a task more frustrating than planking. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
der Gohfelder wrote:Hi Derek! Very nice, I like it! Regards, Bernd Hi Bernd, Thanks for looking in and the kind comments. Bit of a long job, but getting there. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi Derek, looking really nice. Keep up the good work. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
claret wrote:Hi Derek,
Regards Claret Hi Claret, Thanks for taking the time to look in and the kind comments. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, Having literally straightened out my Spitfire build, I`ve come back to the Sots. This is a small update, but a lot of work has been done. (most of it repetitive) ie: gun port lining As for the gunwales, I asked for some advise on the best way to hold them in place while the adhesive set. I would like to thank those who offered their ideas to this issue and especially Alan (Gandale), whose method I finally used. The method used is the drill and map pin method, which gave an unexpected bonus of tree nailing if you look close, even though the gunwales have been painted black after filling the holes made. Below are the results so far What next ? Finish the lower gunwale Line seven more gun ports Then, I can turn it over and do the other side. Happy building Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi dell, Must say she's looking good, I like the choice of colour well done m8. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Del, This is looking good, will continue to watch this one. Steve
tf64 wrote:Hi dell, Must say she's looking good, I like the choice of colour well done m8. Regards Trev. Hi Trev, Thanks for taking a look. As for the colour scheme I`m using the official Sots set and I must say I`m very impressed with results for consistency. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
stevie_o wrote:Hi Del, This is looking good, will continue to watch this one. Steve Hi Steve, Thanks for the positive comments. Some of the repetitive sessions do get to me at times, but that`s why I change tack to another build every so often. I also think it helps to put you back on track and pays dividends in the end results when you return to the previous build. Thanks for looking in and happy building Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 16/06/2013 Posts: 284 Points: 859 Location: Cape Town, South Africa
It did came out great. The paint job and veneer does not seems to be damaged. I'll check in again to watch how you had progressed. "Rather try and fail than had failed to try".Sovereign of the Seas Model Space forum: Marcel's build
Fab work Derek and I'm pleased my method worked out for you..... I had the same effect where after filling the holes I was left with what looked like treenailing..... She's looking great so keep up the good work..... will be following.... Regards Alan
Marcel wrote:It did came out great. The paint job and veneer does not seems to be damaged. I'll check in again to watch how you had progressed. Hi Marcel, Thanks for looking in, there are a few very small bits that will need touching in with a spot of paint(mainly inside the gun port linings) but nothing major thankfully. Happy Building Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Nice work Del looking bril  rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Gandale wrote:Fab work Derek and I'm pleased my method worked out for you..... I had the same effect where after filling the holes I was left with what looked like treenailing..... She's looking great so keep up the good work..... will be following.... Regards Alan Hi Alan, Thanks for looking in. Not sure which is the more trying task, planking or lining the gun ports. That said, still not in a rush even though I`m really looking forward to getting into some main building sections for a bit of a change, cos you see a big difference in a short period of time. Hey Ho just have to wait a while longer Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
