Hi All, Whilst literally waiting for paint to dry, I was thinking about the next stage of my Sots build. Painting strip wood for the gun port inserts and the gunwales. So had a look at what was laying around in my build room and come up with this. Items required: Length of wood to suit. Four 90 degree brackets 2 x nut and bolt (I had threaded rod and wing nuts available) 4 x mini clamps (most of us must have them Eh) Process: Cut wood base to suit (mine 14.5 inches for 12 inch strip wood) Screw a bracket on to each end of the base. Bolt other two brackets on top (see first photo) Clamp strip wood onto top bracket and paint/ spray. Simple. Here`s the pics:   Useful or not, I`ll let you decide. Happy Building Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice idea J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
jase wrote:Nice idea J Thanks Jase, Just an easy way to keep the fingers out of the way of the paint. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 23/04/2013 Posts: 287 Points: 859 Location: Hartbeespoort, NW, South Africa
Hi Derek Great idea! Regards Kobus
Current Build HMS Sovereign of the Seas - First Build
KobusBeukes wrote:Hi Derek Great idea! Regards Hi Kobus, Just a simple idea to keep the fingers clean and all with stuff I had lying around. Used it today and it worked a treat. Thanks for taking the time to take a look. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Derek It' the simple ideas that usually works the best! Regards Kobus
KobusBeukes wrote:Hi Derek It' the simple ideas that usually works the best! Regards Hi Kobus, That`s very true Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
