Grease Options
Supaheli
#1 Posted : 19 December 2013 07:25:44
just wondering where can i find the exact same bevel gear grease for the diff because the way its sounding at the moment it seems that it requires alot more grease then ive put in it. any suggestions would be greatful
supaheli
ps.or should i use oil instead of grease ???
Supaheli
#2 Posted : 19 December 2013 21:48:14
General purpose or graphite grease is okay to use which can be found at and automotive store, or you can purchase diff grease of various types via a model car retailer, such as an 'anti-fling' type which adhere's to the gears better.
On no account should you use oil of any description, the diff unit is not sealed, you would end up with oil seepage and the diff eventually run dry.
Supaheli
#3 Posted : 20 December 2013 00:35:09
would lithium grease be ok to use...and should i fully pack it or just enough to coat the gears. i take it mixing of grease would be wrong so with the grease ive used from the issue what would i use to flush it all out
Supaheli
#4 Posted : 20 December 2013 09:58:25
Lithium is okay. Molybdenum (Moly) grease is mainstream, and if you want to go up market, then Mobil 1 synthetic grease.
Personally I wouldn't mix, but you should be okay. WD40 can be used for grease removal.
You need to pack/coat as shown in the instructions.
This page was generated in 0.200 seconds.
