16 Pages «<45678>»
Mantua's RMS Titanic Options
#101 Posted : 18 December 2013 16:22:27
Hi Alan, BigGrin
Looking good from here matey.
Nice work, will follow with interest, Cool
#102 Posted : 18 December 2013 20:41:48
Foz wrote:
Really fine work Alan. Am looking forward to seeing this build lit up.
Foz ThumpUp ThumpUp
Thanks Foz, lighting this beast will be some time yet but at least I have the semblance of a plan in my head.... Blink Blink .. Thanks again, appreciated....Cool Cool
#103 Posted : 18 December 2013 20:55:17
jase wrote:
Hi Alan,
Guessing your camara flash is messing with the colours a bit. Just interested whos paints you are using and what you have for paint referance?
Hi Jase, camera can play tricks but what you see is close.... Paints used so far are Humbrol rust for the well deck lower walls and Humbrol No 34 flat white for the upper.... The references being used so far are TRMA's colour reference chart, finartmodels build which is reportedly the most accurate Titanic model ever built, The Model Makers Manual by Peter Davies-Garner plus other well known web sites including Rivet Counter..... Will be using TRMA's colour reference guide for the vast majority of the painting.....Cool Cool .. From what I have seen and read so far there is no definitive proof on exact colour shadings but only best guesses using best available info, there are no paint samples surviving to go by.... Hope this answers your question.... Cool Cool .. Thanks for looking in and commenting, it is very much appreciated....Cool Cool
Kind regards
#104 Posted : 18 December 2013 20:56:17
delboy271155 wrote:
Hi Alan, BigGrin
Thanks Derek, appreciate your support as always.... Cool Cool
#105 Posted : 18 December 2013 21:05:48
#106 Posted : 18 December 2013 21:10:40
stevie_o wrote:
Looking good so far Alan, when do the planks start going onBigGrin
LOL LOL LOL Thanks Stevie... am miles away from planking the hull yet, instructions say to do a lot of work on the decks first and get them fitted... after that I have to get the wiring and led's in place, work on preventing any light bleed... once that lot is done then I can get down to actually planking the hull..... This build is going to take time... but what a challenge.....Cool Cool
#107 Posted : 18 December 2013 22:35:51
jase wrote:
Hi Alan,
Kind regards
Good to be using multiple sources but you are right Titanic Research and modelling Association is the way I would have gone.
Thanks for Sharing.
#108 Posted : 22 December 2013 20:54:31
Have been experimenting a little on how to produce the bulkhead lights on the well decks and possibly the roof lights for the promenade... Think I have come across a method that looks very acceptable to me.... Cool Cool Started by using 0.5mm eyelets and simply cut the stem off, .5mm meant it didn't look out of scale.. Drilled .4mm holes into the bulkhead and using a little CA glued the eyelet over the hole and left to dry ... Blink Blink Gave the eyelets a coat primer followed by a couple of coats of matt white... Finally, applied Krystal Klear to give the impression of glass.... As I haven't yet ordered led's and fibre optics yet I had to resort to using one of the fibre optics from the xmas tree to see what the effect would be... think I am quite happy with it so far...Cool Cool Sorry for the last photos being a little out of focus, difficult to operate the camera on macro and hold a fibre optic in place.....
Happy building all...
#109 Posted : 22 December 2013 21:23:53
#110 Posted : 22 December 2013 23:30:41
stevie_o wrote:
Well you certainly have some patience Alan, looks like a result though and will have a great effect when done.
Thanks Steve, have just now ordered all the led's, resistors, wiring etc to start lighting this kit. Feel the model would come to life if I can get bulkhead, wall and ceiling lights to light up and fibre optics I believe is the way to go.... time will tell whether it will be a success or not, if not I can always leave the lights switched off.....BigGrin BigGrin BigGrin
moriarty
#111 Posted : 26 December 2013 23:20:20
I will be in awe of this one . Watching this with great interest I am. Always wanted to do this one. Love
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#112 Posted : 26 December 2013 23:28:10
Thanks Moriarty for taking the time to look in.... the way Mantua supply this kit in 5 separate parts, 4 if you are doing the static display makes this a lot more affordable, buying the parts as you need them.... Will be doing all I can to do this build justice and right now am waiting for led's etc to allow me to plan out the lighting. Hoping the parts will start arriving tomorrow to let me continue.....Cool Cool
#113 Posted : 27 December 2013 00:06:21
Nice, looking forward to seeing the spectacle of her finished and light up, should be stunning.
#114 Posted : 27 December 2013 00:10:30
Thanks Jase, think this is going to take some time especially when I look at all the additional mods required just for Part 1, the hull let alone the superstructure..... One step at a time eh.....
#115 Posted : 27 December 2013 14:49:05
Hi Alan.
Looking very nice. look forward to seeing more. Ian.Cool Cool BigGrin
#116 Posted : 27 December 2013 22:31:21
ian smith wrote:
Hi Alan.
Thanks for looking in and commenting Ian... This one is going to be challenging and very enjoyable....Cool Cool
#117 Posted : 05 January 2014 00:03:09
Have finally finished the forward well deck and there were a number of changes than needed to be made.... On the forward bulkhead needed to add the two portholes, add the pipework above the doors on the portside, add two watertight hatchdoors and change the watertight doors from single to doubles. On the rear bulkhead, add all the portholes and the two bulkhead lighting units.... The instructions leave these bulkheads blank with the exception of doors which were all in the wrong place....Cool Cool .. Have also come to the conclusion I hate working with white paint, too easily marked for my liking but am sure technique will improve the more I use it..... Am waiting now for the arrival of some matt clear varnish to protect the bulkheads... Cool Cool .. Tomorrow I hope to have the forward well deck fitted and do some testing on lighting the portholes with FO.... then onto the aft well deck Cool Cool...
In regards to the lighting I have had to consider some key changes to the build sequences... Instructions say to fit all the decks in place before moving onto the planking stage. If I do this then I will not have any access to modify any lighting arrangements should it be needed so have decided that I will simply pin the decks in place so they can be removed once the planking is complete.... Also on some of the tests I have done, the amount of light coming through the portholes on the bulkheads appeared to be very limited and I put this down to the thickness of the bulkheads and it will be the same for the hull when planked as she is double skinned..... I think my only option here is to use fibre optics throughout together with leds on their own... By being selective on the portholes this means I can have some lit with FO, some showing dull ambient light and some not lit at all, am hoping this will give me the correct balanced look.... Time will tell.....Cool Cool
#118 Posted : 05 January 2014 00:54:56
Hi Alan,BigGrin
Lovely work on what appears to be a really good kit.
One suggestion, (If not already put forward)take a look at minibrass. They do a wealth of brass etch for the Titanic in a multitude of scales, 1:200 included.
Titanic Etch
I realise it`s not cheap, as I have costed the etch for my Hachette build, but it may give you ideas as to things you can improve with your kit, if needed.
I love the Titanic as well, so "Happy Building", will be watching with interest. Cool
#119 Posted : 05 January 2014 10:51:30
delboy271155 wrote:
Hi Alan,BigGrin
Titanic Etch
Hi Derek, thanks for looking in and your kind comments.. Cool Cool . I have been looking at the Minibras etch sets and although pricy they are impressive but have also noticed some of the doors are the wrong kind and some watertight hatches are in the wrong position.... That said, the etch supplied with the kit is also very good even though it is made of thin ply rather than brass, the ply is very flexible and remarkably strong.. Will post some close up photo's this evening to give you and idea of the detail.... The only thing I am not too keen on is the railings and stairways so minibras railings could very much be on the wish list, stairways will have to be thought about ....Cool Cool ... Thanks again......Cool Cool
#120 Posted : 05 January 2014 17:45:07
As promised, here is a couple of close up pics of the supplied ply etch.... Most of it will be used but think the railings will be left out.... Cool Cool
Guest (6)
16 Pages «<45678>»
This page was generated in 0.266 seconds.
