Build guide for layer 7,8,9 missing? Options
Rchuzh
#1 Posted : 15 December 2013 13:47:24
Ahoy! I wanted to ask whether you guys face the same problem as me. I found out that they missed out building guild for layer 7,8,9. Huh
#2 Posted : 15 December 2013 14:03:11
Hi
Welcome to the forum, if you are referring to the planking of the hull then layers 7 onwards are covered from issue 24 page 12-13. This is where you use the taper template for the stern planks
Hope this is what you mean
Rchuzh
#3 Posted : 15 December 2013 14:17:25
But I found out that that the issue in Malaysia differ with the UK issue.
#4 Posted : 15 December 2013 14:43:28
Hi
It looks as though the images you showed are from issue 23, but your right there are slight differences between those and my issue. Have you looked here - http://forum.model-space...aspx?g=posts&t=1095
This is the official guide and for me at times was even more useful than the magazines.
Rchuzh
#5 Posted : 15 December 2013 14:53:55
But on the following issue it missed out the steps for layer 7,8,9. Or may be can you take a pic of your issue 24 for me so I can show it to my distributer.
#6 Posted : 15 December 2013 14:54:36
Rchuzh
#7 Posted : 15 December 2013 14:56:34
Thanks!BigGrin
#8 Posted : 15 December 2013 15:27:53
Rchuzh
#9 Posted : 16 December 2013 12:25:15
Thank you and wish you a Merry Christmas!LOL
#10 Posted : 16 December 2013 13:29:38
Just so you are aware, the Malasian HMS Victory series has a differing sequence to the UK series.
The overall parts content and end result is the same, but some of the instructions are provided at different points.
So its not that you are missing instructions, but that they are located elewhere in the series, therefore you should follow the build sequence contained within the magazines you are receiving rather than the UK sequence.
Rchuzh
#11 Posted : 16 December 2013 15:56:14
Thanks!BigGrin
This page was generated in 0.194 seconds.
