While I am waitng Options
GilShapley
#1 Posted : 14 December 2013 21:29:31
Having finished the Victory I have now started the Hummer
The difference in the build is quite marked. The Victory required a considerable amount of "manufacture of parts" plus a lot of time to construct the monthly parts. Is was difficult at times to keep up with the deliveries.
Not so with the Hummer. Being mainly constrction of parts supplied I have found it easier to keep up to date with deliveries inso far as i now have some spare modelling time ( Thats construction not the cat walk variety)
To fill in I have purchased from Cornwall Models a Roman Catapult kit
The does require some manufacturing of parts. However the wood supplied is of the laser cut plywood type. Having purchased some Oak planks to construct my Victory display case I am using offcuts to replace the parts supplied with the kit. Using the parts supplied as templates I am replacing where I can with Oak
Pictures of parts constructed so far attached and more will follow as I procede
As always constructive comments are welcombe
Current Build:-
#2 Posted : 15 December 2013 10:12:57
Hi Gil, Cool
Looks like a nice detailed kit.
Keep the pics coming, I like some of these smaller builds.
#3 Posted : 15 December 2013 10:39:10
Fantastic, always good to see something different on the forum, will be watching your build Cool
GilShapley
#4 Posted : 16 December 2013 20:48:11
Well thats the frame built
Now for the twidly bits
Should be fun
Current Build:-
GilShapley
#5 Posted : 29 December 2013 19:32:29
Finished this build
Must say the "instructions" are basic to say the least
Mainly a series of photos "It should look like this" without any hint as how to get there.
As I mentioned before I have replaced most of the components with Oak using the provided parts as templates
Am now going to build the Norman Catapult. If it carries on like this I will need a bigger house.
Photos attached
Current Build:-
#6 Posted : 29 December 2013 20:21:01
BigGrin Hi Gil
looks a beast and nice work
#7 Posted : 29 December 2013 20:42:09
very nice mate, well done Cool Cool Cool
GilShapley
#8 Posted : 30 December 2013 17:57:09
Now going to start on the Norman Catapult
Picture of Parts attached
Will add more as the build proceeds. Not sure if I am going to use Oak for this one will have to check what offcuts I have left
Is it me or can anyone else see Homer Simpson in the picture?
Confused Confused Confused Confused Confused Confused
Current Build:-
#9 Posted : 30 December 2013 18:06:35
#10 Posted : 30 December 2013 19:53:56
BigGrin Hi Gil
Very nice by the way did you get all these kits as a job lot LOL Drool LOL
GilShapley
#11 Posted : 31 December 2013 12:53:02
No not a job lot. Decided to pre-empt the socks and jumpers for Xmas by buying my own presents. Did let the wife wrap them
BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
The Roman Catapult does work to a large degree.
Both the Handles that tension the cables at the base of the Catapult arm work with the ratchet holding the cable nice and tight. However I constructed the chassis before I installed the windlass
What I should of done was attach the windlass to its axle before installing it, making sure it would turn freely in the holes in the chassis and then put it in place when gluing the chassis together. That way I could have got the ratchet working for this as well as the catapult arm. As it is the windlass is quite stiff on its axle and will turn OK and still hold the cable that pulls the arm back to its firing position. The stones are glued in place so I will not be firing it.
Hope that makes sense.
Current Build:-
GilShapley
#12 Posted : 15 January 2014 20:51:36
Norman Catapult
Phase One
As with the Roman Catapult I have decided to replace most of the supplied parts with one made fron Oak
Using the parts supplied as tenplates I have duplicated the components
Phase Two will start shortly with me starting the construction. Having already built one of the Mantua kits I am prepared for the somewhat sparse building instructions
Some pictures attached with more to follow as the build preceeds
Current Build:-
GilShapley
#13 Posted : 26 January 2014 13:52:16
The Norman Catapult progresses. Taking a bit longer than the Roman catapult as there are more fiddly bits and the instructions are as poor for this build as the previous catapult.
It does not help when the pictures in the instructions seem to differ from page to page. Still gives me a chance to improvise
up todate picture attacheed. Will add more later
Current Build:-
GilShapley
#14 Posted : 26 January 2014 14:14:09
More completed parts
Current Build:-
#15 Posted : 26 January 2014 14:26:04
The quality of these kits looks top notch
GilShapley
#16 Posted : 26 January 2014 14:32:52
The Quality is not too bad for laser cut ply but I have replaced the majority of the components with Oak Parts using the supplied parts as templates. Takes longer but no painting and a better finish. More of a challenge to
Cool Cool Cool Cool Cool Cool
Current Build:-
#17 Posted : 26 January 2014 14:48:30
Sorry Gil I missed that part, and in that case all credit to you as the re-cut parts look great Cool
GilShapley
#18 Posted : 30 January 2014 21:30:41
Well that that one done and I have just got the paint for the Hummer so thats the next job.
Still looking for my next interim build
Possibles :English Caronade 18th Century
Napoleonic Cannon 18th Century
Or another big build. Has anyone tried the Tiger Tank build by Hachette
Current Build:-
This page was generated in 0.458 seconds.
