 Hi All This is where my build diary will be for the above model but first some information The World's Largest "Submarine Carrier" The I-400 was a submarine the likes of which the world had never seen before. At the time of their completion, the I-400 and her sister ships were the largest, and arguably the most advanced submarines in the world. With a 122m length, 12m width, and 6,560 ton displacement, their size rivalled that of destroyers of the time and their amazing endurance could allow them to traverse the globe one and a half times. Loaded with 3 Seiran bombers, the planned attack on the Panama Canal was only moments away from reality. Diverted to attack the gathering Allied invasion fleet at Ulithi, the war ended before the submarines could launch their strike. Both I-400 submarines never had the opportunity to see action due to the ending of WW2. It is said that due to its superior design, the I-400 is the predecessor to modern day strategic nuclear missile submarines. About the Model •1/350 Length: 348.5mm. •Transparent parts are included in the set allowing you to easily see the three hangar stored Seiran aircraft. •Photo-etched parts are included to depict the crane arm, aft antenna support, Seiran propellers as well as hand rails. A guide sticker sheet for hand rail installation is also included. •The kit also comes with four metal torpedoes. Transparent parts for the Seiran canopy add greater realism to the model. •Forty-eight 1/350 scale figures are included to spice up the model. • Includes Photo-Etched railings and torpedo fins. • railing positioning guide stickers • 4 metal Type 95 torpedoes are included and can be displayed with included display rack. Just like the actual submarine, 3 Seiran aircraft with wings folded can be stored inside the hangar. http://www.tamiya.com/en...ts/78019i_400/index.htm regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All There's is plenty of information available now on these almost forgotten submarines a new book recently published gives a full history of the boats and is the most comprehensive guide that's available http://www.amazon.co.uk/...8-16&keywords=i-400
also there is a documentary on U-Tube http://www.youtube.com/watch?v=q5-ijBs8iJA
enjoy Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking forward to seeing this build Andy
Another one to follow with interest Andy, looking forward to seeing what you come up with with this one..... good luck with the build.... Regards Alan
Joined: 28/04/2013 Posts: 158 Points: 486 Location: England Cheshire
Hi Andy, It could be a fascinating build, I am looking forward to seeing it go together.
Tony.
 Hi Tom, Alan and Tony I have been looking forward to this for a while too, should be extra special with the see through hangar feature. Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Started the build today after washing the parts and giving everything a spray of undercoat in the week. This is one of Tamiya's waterline models so the lower hull which can be discarded if doing a waterline model is always moulded in red plastic. Firstly it was to glue the display base together then add the nuts for the screws inside the lower hull with there caps and then add the weights. A good deal of the external fittings like the diving planes, rudders prop shafts,guards and some etch have been fitted but still more to add yet. Another update soon Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy looking forward to seeing this come together. question... second photo. looks like there is some major sink? or is it the panel lines? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Jase Its panel lines and thin undercoat causing the illusion didn't want to go too thick with the undercoat as there is fine detail on the hull. Thanks for looking in and your comments Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Lovely start Andy... well done... Regards Alan
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Very nice start Andy, look forward to seeing this one progress. Regards Foz
 Hi Alan Thanks for looking in and your comments. Im on hold right now though as im awaiting the wood deck that's been on back order and was posted Friday regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Foz Thanks for your comments and looking in Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, A good start, I think it should be spectacular when complete.
Tony.
 Hi Tony Thanks for your comments and looking in Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, Looks like a nice kit, will watch with interest. There are also numerous sub kits from Heller available on E-Bay at good prices. They are 1:400 scale with some good detail for anyone interested. Keep the pics coming Andy. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Hi Derek Yes I have seen those kits but this is a special sub that was way ahead of its time ,certainly a thinking out of the box project. Thanks for looking in and your comments Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The etch ramp and other etch parts provided for the hull have now been fitted apart from the railings so its on with the painting now. The wood deck has also now arrived and will be fitted soon regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Very nice Andy, looking forward to seeing the wooden deck fitted. regards Foz
 Hi Foz Thanks for your comments and looking in, the deck will look great although by the end of the war they were painted grey Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (7)
