Kas' first wooden ship build Options
kas
#1 Posted : 05 June 2010 23:51:37
Rank: Amateur Level 1
Well here goes my attempt at building this mighty ship. As the title says this is my first ever wooden ship build and after reading many tips and tricks on this forum i finally made a start after recieving issue 6. I went straight into the build with the launch, built the jig as per instructions, then left to dry for 24 hours. Then came the plankingCrying . Shaped the jig with sand paper to achieve contours on the ribs and laid the first planks
This is when i came to a pause and started to read the forum for help. Luckily i found plenty of info regarding planking and went ahead with my attempt at the matter in hand and ended up with this, BigGrin very happy with my result
As you can see, i'm going with the painted finish and this is now primed for and smoothed. Now awaiting next parts before continuing on with the launch.......
In the mean time i made a start on the cannon.
Inspiration for this came from reading with great interest Capt's Brushwork/Painting thread. Still to fit carriage wheels and fine detail which will include greenstuff modeling (Hoping to get this finished over the weekend)
Also made a start on the carronade and the anchor and work on these will take place over this weekend and then i will update my diary.
That is the progress i've made so far....
Until next time, enjoy
Kas (Karl)
Capt Stedders
#2 Posted : 05 June 2010 23:57:52
Sound as the proverbial pound there Kas.
Very neat work there with the rubbing strips and a nice smooth bit of paintwork - all very clean.
ThumpUp
Schnellboots on back burner
Tools.
andylangtree
#3 Posted : 06 June 2010 00:04:41
Very impressive, looks really good. Wish my attempt would look as good as your result.
tf5600
#4 Posted : 06 June 2010 10:07:59
Nice work Kas.
jonny7england
#5 Posted : 06 June 2010 12:54:26
Very impressive Kas...ThumpUp
tom.ganc
#6 Posted : 06 June 2010 14:40:49
Great job Kas. Keep it up.
Tiswas
#7 Posted : 06 June 2010 17:12:06
Nice work Kas.Keep at it.
TIS
kas
#8 Posted : 08 June 2010 22:38:31
CARRONADE
Just a quick update as to where i am. Managed to get the carronade completed to a finished item i'm happy with, just need to add the tackle blocks to the rear eyes which i have not glued in position. Bought some 3mm tackle blocks from cornwall models to replace the kit blocks as in my opinion these are to big a scale to be convincing.
Reworked the barrel fixing using Greenstuff putty(another tip from the capt) and also add the additional ring. GS also helped with the carriage wheels and the mid angled eye of the sliding gun carriage. The base plate has aslo had the sliding slot cut out using the drill, cut and micro file method.
Last job was to paint using Capt Stedders method shown in the brushwork thread which is a task on its own but well worth the effort. If only i could do it justice like the Capt can.
ANCHOR
Completed the anchor also this weekend. Pretty much standard build as per mag apart from enlarging the brass ring using some brass rod from cornwall models. Added the puddening using black thread the added the siezings using a white thread, not perfect but will do. May come back to this at a later date as i used a cotton thread which is quiit fluffy even after going through diluted pva. Macro shows the slightest hairCursing .
Still got some work to do on the 12lb cannon but will post this up when finished.
Bit of luck the postie will leave me a nice parcel tomorrow, then i can make a start on the keel and get the launch up to speed...
kas
#9 Posted : 22 June 2010 00:31:58
LAUNCH UPDATE
Not much done this week due to work, but after much debate in the launch thread on paint colour options and details i've decided to replace the kit decks with scratch built planks painted a dark brown to represent natural timber. When i fit the thwarts, i will do these in the same dark natural option too.
Still to add the black stripe on gunwhale.
Capt Stedders
#10 Posted : 22 June 2010 01:13:06
*Sniff*
It is really satisfying to see that you are trying out the techniques and methods I laid out in the brushworks thread and, to a very large degree, I am impressed by your efforts.
The painting is smooth, and the attention to detail is high.
I can't take any credit for your craftsmanship though - and, as all the other comments suggest, you are making a really nice job of things!
I'm also relieved that you have followed the magazine instructions with regard to the positioning of the oar slots.
Keep up the good work!
ThumpUp
Tools.
kas
#11 Posted : 22 June 2010 01:30:54
Thank you Capt,
Tried to get the oar slots as close to mag as poss but as noted elsewhere, some precise measurements would have been helpful(actual size in mag is not the same actual size model in my handsConfused )
chip
#12 Posted : 27 June 2010 21:12:51
wow all the pic's are great,
am about 4 issues behined all i can say is i hope mine turn out as well as all the ones av seen.
Tiswas
#13 Posted : 27 June 2010 21:47:19
Very encouraging for those of us who haven't started yet. Getting itchy fingers, all my bits are still in their packaging.
TIS
jay7792
#14 Posted : 04 July 2010 18:48:53
All is looking awsome my friend, hope mine turns out even half as good as yours.
_____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
jay7792
#15 Posted : 04 July 2010 18:50:00
TIS
I'm in the same boat as you TIS.LOL LOL
Amati Black Pearl
Mac
#16 Posted : 05 July 2010 10:46:57
looking great matey!BigGrin
Pam's shipyard is closed for now no more room!
kas
#17 Posted : 01 August 2010 23:17:01
BUILD UPDATE
Not much done this month but did go back to the launch as wasn't happy with the progress i had made. Something didn't look right after painting the deckboards white so decide to stain instead. After researching the photos of the actual launch and noting the natural fininsh was quite dark and i set off to diy store and returned with a tin of dark oak wood stain and set to work. Ended up with this result
(photo's could be in better light but was taken late in day) (note to self)
LAUNCH ANCHOR
Built kit anchor as mag instruction and offered up to launch, decided like many others that said part is to large so set to work on scratch built item. Four size 10 fishing hooks where used for this, starting with the first just snipped on the bend to leave a shorter hook. Remaining 3 had the shanks and eye removed and then clued to the first and then a small drop of Greenstuff moulded around the bends to add a bit more strength
kas
#18 Posted : 01 August 2010 23:25:20
HULL PROGRESS
All ribs assembled per instructions. Keel assembled and placed in jig. Ribs dry fitted for now.
Now working on finishing the launch and will try to post progress tomorrow or tuesday......
tf5600
#19 Posted : 01 August 2010 23:51:59
Looks great Kas, keep it up.
Ferret
Tiswas
#20 Posted : 03 August 2010 21:04:36
Hull looks nice and straight, launch coming along nicely, keep up the good work.
TIS
This page was generated in 0.183 seconds.
