Joined: 10/10/2012 Posts: 66 Points: 191 Location: UK
Its me again. I have a question about building the rolling chocks. Because shipments 12 and 13 were missing parts, ModelSpace was good enough to send replacements. This has resulted in having extra parts. I am wondering, instead of gluing slats together I could glue 3 sets of two rolling chocks (each pair glued as described in step 81, page 154 of the instructions) and then glue the 3 pairs together eliminating the need to remove the excess from the slats? I would then shape as per the instructions. Does this make sense? Anyone's advice is greatly appreciated. Thanks, Dan Current Builds: Yamato On the Bench: Akagi, USS Missouri
 Hi Dan You could do that quite easily with your spare parts and as long as your happy do it, just ensure the overall correct length/ sizes are adheared too regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
