Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Well done Benny, over to you. Peter Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
 Rank: Pro Groups: Registered
Joined: 05/12/2012 Posts: 258 Points: 754 Location: manchester
an easy one full name of the man called the red baron,the famous type of aircraft he flu, and the name of the pilot reported to have shot him down benny.
will try another one if to hard give the common name given to the battle in the Ardennes. benny.
Hi Benny Manfred Albrecht Freiherr von Richthoven, Fokker DR1 (a copy of a captured Sopwith Triplane) and Capt. Arthur 'Roy' Brown (although current speculation suggestshe was actually shot down by an Australian AA machinegunner from the ground! Battle of the Bulge? Sorry, been a bit busy lately! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
hi that is correct on both questions so over to you robin. benny
Thanks Benny! OK then, Royal Navy Guns. Out of the 32lb Long Gun and the 68lb Carronade, which required the fewer number of crew? And which had the higher rate of fire and why? Best of luck Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Plymouth57 wrote:Thanks Benny!
Best of luck
Robin Ok total guess i am going for carronade as having fewer crew and had the higher rate of fire because it took longer to recoil and load the long gun  ?? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Right on both counts Jase! The carronade was quicker as you say because of the shorter barrel and also because of the design of the carriage. The carronade could only recoil back along the slider groove and could simply be pushed aound its front pivot to aim. The long guns could easily swerve sideways when they recoiled which required extra crew to manhandle them back in line with big wooden 'crowbars'. Well done and over to you. Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
right then During the English Civil War the Parliamentarians held London. In which city did the Royalists establish their rival capital? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
hi jase he moved it round over the years but are you thinking oxford. benny.
benny b wrote:hi jase he moved it round over the years but are you thinking oxford. benny. Yes i am well done over to you “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
easy one name the planes used on the dolittle raid and were they took of from. benny.
the questions can,t be to hard. benny.
 B25 and the aircraft carrier hornet Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
correct over to you. benny.
 Where is the expression ' Cock Up' from and why Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Best answer this then . When an arrow shaft was fletched one of the flight feathers used was a cock feather the other two were not. So when firing the arrow from a bow the cock feather should be the top most vertical this ensures a straight and true flight to the target but if the arrow was loaded with out checking properly or in a panic it could fly to the left or right so this lead to the saying 'its a cock up' shortened to 'cock up'. And that's the answer Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 ok an easy one what was the name of the 1st British tank Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
is it the mark 1 first used on the somme. benny.
 sorry Benny perhaps i should be more specific and say it was the 1st test tank show to the british military Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
